Ga door naar hoofdinhoud
Meizu MX3 Volume Control and Power Button Replacement
Wat je nodig hebt
  1. Meizu MX3 Volume Control and Power Button Replacement, Removing the Back Cover: stap 1, afbeelding 1 van 3 Meizu MX3 Volume Control and Power Button Replacement, Removing the Back Cover: stap 1, afbeelding 2 van 3 Meizu MX3 Volume Control and Power Button Replacement, Removing the Back Cover: stap 1, afbeelding 3 van 3
    • Insert the plastic opening tool in between the charging port and the back case of the device. Slowly move the tool to the left of the until you come the top by the power button.
    • Using a paper clip or pointed edge spudger push in the pin located in the bottom right hand corner of the back of the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. Meizu MX3 Volume Control and Power Button Replacement, Removing the Screws in the Internal Casing: stap 2, afbeelding 1 van 3 Meizu MX3 Volume Control and Power Button Replacement, Removing the Screws in the Internal Casing: stap 2, afbeelding 2 van 3 Meizu MX3 Volume Control and Power Button Replacement, Removing the Screws in the Internal Casing: stap 2, afbeelding 3 van 3
    • Using one of the small Phillips screwdriver bits provided unscrew the 11 screws present on the protective plastic plate under the device case.
    Vraag FixBot
    Voeg opmerking toe
  3. Meizu MX3 Volume Control and Power Button Replacement, Removing the Internal Casing: stap 3, afbeelding 1 van 3 Meizu MX3 Volume Control and Power Button Replacement, Removing the Internal Casing: stap 3, afbeelding 2 van 3 Meizu MX3 Volume Control and Power Button Replacement, Removing the Internal Casing: stap 3, afbeelding 3 van 3
    • After the 11 screws are loosened use the plastic opening tool and gently pry the protective plate from the back of the device.
    • Once the plate is off, use the same tool to gently remove the 3 ribbon cables located directly above the battery.
    • On the left side of the battery on the phone case, there is a groove where the plastic opening tool can be inserted to pry the battery up and out. The battery might be glued to the phone so exercise caution.
    • Note: The battery and motherboard does not need to be removed in order replace power and volume buttons.
    Vraag FixBot
    Voeg opmerking toe
  4. Meizu MX3 Volume Control and Power Button Replacement, Removing the Power and Volume Buttons: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • After the plastic plate is removed, tweezers can be used to remove and replace the power and volume buttons from the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mandela Robin
876 Reputatie
6 handleidingen geschreven
USF Tampa, Team 15-2, Remmell Fall 2014 Lid van USF Tampa, Team 15-2, Remmell Fall 2014
USFT-REMMELL-F14S15G2
4 Leden
27 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 36
Altijd: 2,236
