Ga door naar hoofdinhoud
Maylong MN-1000P Screen Replacement
Wat je nodig hebt
    1. Maylong MN-1000P Screen Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
      • Place the netbook top down, with the opening of the netbook facing you.
      Vraag FixBot
      Voeg opmerking toe
    2. Maylong MN-1000P Screen Replacement: stap 2, afbeelding 1 van 1
      • Remove the six 6mm Phillips #00 screws from the netbook.
      Vraag FixBot
      Voeg opmerking toe
    3. Maylong MN-1000P Screen Replacement: stap 3, afbeelding 1 van 3 Maylong MN-1000P Screen Replacement: stap 3, afbeelding 2 van 3 Maylong MN-1000P Screen Replacement: stap 3, afbeelding 3 van 3
      • Remove the sticker in the middle of the netbook.
      • Remove the middle 6mm Phillips #00 screw.
      Vraag FixBot
      Voeg opmerking toe
    4. Maylong MN-1000P Screen Replacement: stap 4, afbeelding 1 van 1
      • Using two plastic opening tools, pry off the bottom of the netbook by going around the edges.
      Vraag FixBot
      Voeg opmerking toe
    5. Maylong MN-1000P Screen Replacement: stap 5, afbeelding 1 van 1
      • Remove the bottom of the netbook by lifting the corners.
      Vraag FixBot
      Voeg opmerking toe
    1. Maylong MN-1000P Screen Replacement, Battery: stap 6, afbeelding 1 van 2 Maylong MN-1000P Screen Replacement, Battery: stap 6, afbeelding 2 van 2
      • Pinch the red and black wires connected to the section closest to the small white connector, and pull to remove them from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Maylong MN-1000P Screen Replacement, Screen: stap 7, afbeelding 1 van 1
      • Remove the six 6mm Phillips #00 screws from both sides of the netbook.
      Vraag FixBot
      Voeg opmerking toe
    2. Maylong MN-1000P Screen Replacement: stap 8, afbeelding 1 van 2 Maylong MN-1000P Screen Replacement: stap 8, afbeelding 2 van 2
      • Pull the top of the computer and the back side of the computer away from each other until they are detached.
      • Flip the entire computer over so you can see both the screen and keyboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Maylong MN-1000P Screen Replacement: stap 9, afbeelding 1 van 2 Maylong MN-1000P Screen Replacement: stap 9, afbeelding 2 van 2
      • Remove all the black circular pads from around the screen.
      • Remove all 6mm Phillips #00 screws from around the screen bezel.
      Vraag FixBot
      Voeg opmerking toe
    4. Maylong MN-1000P Screen Replacement: stap 10, afbeelding 1 van 1
      • Using a plastic opening tool, pry off the screen bezel.
      • After detaching the screen bezel, pull up on the bezel near the hinge area.
      Vraag FixBot
      Voeg opmerking toe
    5. Maylong MN-1000P Screen Replacement: stap 11, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Use tweezers to gently pull on the black and white wires at the top of the netbook until the white connector detaches.
      Vraag FixBot
      Voeg opmerking toe
    6. Maylong MN-1000P Screen Replacement: stap 12, afbeelding 1 van 1
      • Use your fingers to pull on the green, red, black, and white intertwined wires at the bottom of the netbook until the white connector detaches.
      Vraag FixBot
      Voeg opmerking toe
    7. Maylong MN-1000P Screen Replacement: stap 13, afbeelding 1 van 3 Maylong MN-1000P Screen Replacement: stap 13, afbeelding 2 van 3 Maylong MN-1000P Screen Replacement: stap 13, afbeelding 3 van 3
      • Detach the wide yellow ribbon cable connected to the screen from the computer.
      Vraag FixBot
      Voeg opmerking toe
    8. Maylong MN-1000P Screen Replacement: stap 14, afbeelding 1 van 2 Maylong MN-1000P Screen Replacement: stap 14, afbeelding 2 van 2
      • Flip the computer over.
      • Disconnect the red, green, black, and white intertwined wires from the connector to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    9. Maylong MN-1000P Screen Replacement: stap 15, afbeelding 1 van 3 Maylong MN-1000P Screen Replacement: stap 15, afbeelding 2 van 3 Maylong MN-1000P Screen Replacement: stap 15, afbeelding 3 van 3
      • Remove the black tape holding down the red, green, black, and white intertwined wires.
      • Remove the screen.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
katelyn buckman
553 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 19
Altijd: 384
