Ga door naar hoofdinhoud
Master and Dynamic MW50 Wireless Connector Replacement
Wat je nodig hebt
  1. Master and Dynamic MW50 Wireless Connector Replacement, Master and Dynamic MW50 Disassembly: stap 1, afbeelding 1 van 3 Master and Dynamic MW50 Wireless Connector Replacement, Master and Dynamic MW50 Disassembly: stap 1, afbeelding 2 van 3 Master and Dynamic MW50 Wireless Connector Replacement, Master and Dynamic MW50 Disassembly: stap 1, afbeelding 3 van 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Wireless Connector Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Wireless Connector Replacement: stap 3, afbeelding 1 van 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Wireless Connector Replacement, Wireless Connector: stap 4, afbeelding 1 van 3 Master and Dynamic MW50 Wireless Connector Replacement, Wireless Connector: stap 4, afbeelding 2 van 3 Master and Dynamic MW50 Wireless Connector Replacement, Wireless Connector: stap 4, afbeelding 3 van 3
    • Remove the 2mm screw holding the side cover plate in place with a JIS #00 screwdriver.
    • Move the side cover off to the side.
    • The black cable connected to the motherboard from the side cover can be gently pulled off from the motherboard side. It isn't soldered on.
  5. Master and Dynamic MW50 Wireless Connector Replacement: stap 5, afbeelding 1 van 1
    • Pull the black tape holding the connector in place.
  6. Master and Dynamic MW50 Wireless Connector Replacement: stap 6, afbeelding 1 van 1
    • Desolder the connector from the motherboard.
    • Refer to this picture for soldering the connector back to the motherboard.
  7. Master and Dynamic MW50 Wireless Connector Replacement: stap 7, afbeelding 1 van 1
    • Solder the new Bluetooth connector into place.
Conclusie
Neil Patel
162 Reputatie
1 Handleiding geschreven
Cal Poly, Team S1-G4, White Winter 2019 Lid van Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 255
