Ga door naar hoofdinhoud
Master and Dynamic MW50 Right/Left Speaker Replacement
Wat je nodig hebt
  1. Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: stap 1, afbeelding 1 van 3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: stap 1, afbeelding 2 van 3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: stap 1, afbeelding 3 van 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Right/Left Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Right/Left Speaker Replacement: stap 3, afbeelding 1 van 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Right/Left Speaker Replacement, Right/Left Speaker: stap 4, afbeelding 1 van 1
    • Desolder the two wires connected to the speaker.
  5. Master and Dynamic MW50 Right/Left Speaker Replacement: stap 5, afbeelding 1 van 1
    • Use a heating gun to remove the glue from the speaker.
    • Once the glue is removed, gently pull out the speaker.
Conclusie
Katie Dunnigan
85 Reputatie
1 Handleiding geschreven
Cal Poly, Team S1-G4, White Winter 2019 Lid van Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Leden
12 handleidingen geschreven
Één opmerking
This is awesome but Master & Dynamic don’t sell replacement 45mm 32 ohm drivers and won’t share the specs.
If anyone know where to get a replacement which will work well with these headphones please share!!!
paul
bloodygoose@icloud.com
psullivan_au - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 679
