Inleiding
You will want to disassemble the Left side of the headphones. This guide requires soldering, If you don't know how to solder, click here for a great guide.
Wat je nodig hebt
Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
Remove the 2mm screw holding the side cover plate in place with a JIS #00 screwdriver.
Move the side cover off to the side.
To reassemble your device, follow these instructions in reverse order. You may want to use the picture from Step 5 to correctly re-solder your device.
Één andere persoon heeft deze handleiding voltooid.
