Ga door naar hoofdinhoud
Master and Dynamic MW50 Battery Replacement
Wat je nodig hebt
  1. Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: stap 1, afbeelding 1 van 3 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: stap 1, afbeelding 2 van 3 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: stap 1, afbeelding 3 van 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Battery Replacement: stap 3, afbeelding 1 van 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Master and Dynamic MW50 Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Remove the tape attaching the thicker white wire to the battery. You may consider keeping the tape to reattach the wire later.
  5. Master and Dynamic MW50 Battery Replacement: stap 5, afbeelding 1 van 1
    • Desolder the two wires circled here.
  6. Master and Dynamic MW50 Battery Replacement: stap 6, afbeelding 1 van 2 Master and Dynamic MW50 Battery Replacement: stap 6, afbeelding 2 van 2
    • Use an iFixit opening tool or something similar to pry out the battery.
    • There are two small tabs circled here that are holding the battery in. Push these down while prying to make the battery come out easier.
Conclusie
Tyler Guffey
208 Reputatie
2 handleidingen geschreven
Cal Poly, Team S1-G4, White Winter 2019 Lid van Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Leden
12 handleidingen geschreven
Één opmerking
Hi, do you know where it’s possible to buy replacement batteries??
Mike - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 40
Altijd: 1,769
