Ga door naar hoofdinhoud
Martian Victory Motherboard Replacement
Wat je nodig hebt
  1. Martian Victory Motherboard  Replacement, Back Plate: stap 1, afbeelding 1 van 2 Martian Victory Motherboard  Replacement, Back Plate: stap 1, afbeelding 2 van 2
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory Motherboard  Replacement: stap 2, afbeelding 1 van 1
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory Motherboard  Replacement, Lithium Battery: stap 3, afbeelding 1 van 1
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory Motherboard  Replacement: stap 4, afbeelding 1 van 1
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory Motherboard  Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
  6. Martian Victory Motherboard  Replacement: stap 6, afbeelding 1 van 1
    • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
  7. Martian Victory Motherboard  Replacement: stap 7, afbeelding 1 van 1
    • Use PH00 screwdriver to remove 5.2mm Phillips head screw
  8. Martian Victory Motherboard  Replacement: stap 8, afbeelding 1 van 3 Martian Victory Motherboard  Replacement: stap 8, afbeelding 2 van 3 Martian Victory Motherboard  Replacement: stap 8, afbeelding 3 van 3
    • Use ESD safe tweezers to remove the gold ribbon cable.
    • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
  9. Martian Victory Motherboard  Replacement: stap 9, afbeelding 1 van 2 Martian Victory Motherboard  Replacement: stap 9, afbeelding 2 van 2
    • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
    • You can now access the parts and pieces on the bottom of, and below the motherboard.
Conclusie
Dominic Coffey
231 Reputatie
2 handleidingen geschreven
IUPUI, Team 3-3, Baechle Fall 2016 Lid van IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 11
Altijd: 189
