Ga door naar hoofdinhoud
Martian Victory LED Screen Replacement
Wat je nodig hebt
  1. Martian Victory LED Screen Replacement, Back Plate: stap 1, afbeelding 1 van 2 Martian Victory LED Screen Replacement, Back Plate: stap 1, afbeelding 2 van 2
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory LED Screen Replacement: stap 2, afbeelding 1 van 1
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory LED Screen Replacement, Lithium Battery: stap 3, afbeelding 1 van 1
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory LED Screen Replacement: stap 4, afbeelding 1 van 1
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory LED Screen Replacement, LED Screen: stap 5, afbeelding 1 van 1
    • Locate the ribbon connection, and use remove the clips holding the strip on each side using needle tool.
  6. Martian Victory LED Screen Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • With a pair of tweezers, carefully remove the ribbon strip connection.
  7. Martian Victory LED Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the screw driver holding the LED screen and Speaker in place.
  8. Martian Victory LED Screen Replacement: stap 8, afbeelding 1 van 1
    • Insert a small flat screw driver under the speaker in order to remove it.
  9. Martian Victory LED Screen Replacement: stap 9, afbeelding 1 van 2 Martian Victory LED Screen Replacement: stap 9, afbeelding 2 van 2
    • Using tweezers, remove the speaker and move off to the side.
  10. Martian Victory LED Screen Replacement: stap 10, afbeelding 1 van 2 Martian Victory LED Screen Replacement: stap 10, afbeelding 2 van 2
    • Place a small flat head screwdriver under the LED screen, and carefully push it out of it's socket.
  11. Martian Victory LED Screen Replacement: stap 11, afbeelding 1 van 1
    • Remove final connection to accelerometer. The LED screen is now separated from the device.
Conclusie
Robert Sanchez
201 Reputatie
2 handleidingen geschreven
IUPUI, Team 3-3, Baechle Fall 2016 Lid van IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 219
