Inleiding
Has your Marshall Woburn been having trouble with high-pitched audio? If so, here is the guide on how to remove the two tweeters. All you need is the standard #1 Phillips Screwdriver head to remove the screws involved with this replacement.
Wat je nodig hebt
On a flat surface, orient the device so that the front grille is facing downward.
Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
Using a Phillips #1 screwdriver, remove the eight 15.8 mm screws attaching the tweeters to the frame.
Disconnect the two wires from the back of each tweeter.
