Ga door naar hoofdinhoud
Marshall Emberton Button Replacement
Wat je nodig hebt
  1. Marshall Emberton Button Replacement, Button: stap 1, afbeelding 1 van 1
    • Remove the rubber casing from the speaker by peeling it off using your nails.
    Vraag FixBot
    Voeg opmerking toe
  2. Marshall Emberton Button Replacement: stap 2, afbeelding 1 van 1
    • Use a TR9 screwdriver to remove the eight 1 cm screws located on top of the speaker.
    Vraag FixBot
    Voeg opmerking toe
  3. Marshall Emberton Button Replacement: stap 3, afbeelding 1 van 1
    • Once all the screws are off, you must pry the plastic piece off using any tool capable of sliding into the crevice. Then easily pop the piece out.
    Vraag FixBot
    Voeg opmerking toe
  4. Marshall Emberton Button Replacement: stap 4, afbeelding 1 van 1
    • On the back side of the plastic piece, there is a circuit which is shown in the picture. Use a TR9 screwdriver to remove two 1.2 cm screws to detach the circuit from the plastic housing.
    Vraag FixBot
    Voeg opmerking toe
  5. Marshall Emberton Button Replacement: stap 5, afbeelding 1 van 1
    • Once the circuit is removed, you may gently pop the button off and easily replace it with a new one.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Asia Baldwin
781 Reputatie
5 handleidingen geschreven
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Lid van CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
5 Leden
12 handleidingen geschreven
4Gids Commentaar
where can i find a replacement button
MANU 1907 - Antwoord Deel
The worst instruction I've ever seen in my life. If you do this, you will break your device.
cool eo - Antwoord Deel
yes, i confirme !!!
Mallet Jp - Antwoord Deel
@cooleo fortunately i figured it out but yeah you ned to disassemble multiple parts. disassemble from the front panel (marshal logo panel is pressure fit, undo the phillips, and take the board out behind it, and then take out the top out + switch.
Daniel Hyunsu Kim - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 183
Altijd: 4,428
