Inleiding
The battery in the Marshall Emberton is responsible for giving power to the speaker and allowing it to turn on. With the help of this guide you will be able to locate the battery and changing the battery.
With an exhausted or degraded battery, battery life decreases significantly and repeated charging is required. Although the battery is located deep inside the speaker, it is very easy to replace.
Wat je nodig hebt
Remove the rubber casing from the speaker using your nails to peel the cover off.
5 andere personen hebben deze handleiding voltooid.
5Gids Commentaar
Add any tools at the top you used in this repair guide and also any replacement parts if you can.
How can i buy battery
How can I buy the battery
How to buy a battery for my emberton?
From where to buy battery? What is the battery specification?
