Inleiding
If you've overheated your stepper, or want to help someone who has, then this is for you. This will show you how to disassemble your Digitizer with a minimum of effort.
Wat je nodig hebt
Use a flat spudger or screwdriver to remove the 1-1/2" cap from the turntable center.
There is a small indentation on the underside of one side of the cap.
Loosen the exposed T15 screw.
You do not need to remove it from the turntable, but it must be completely loosened.
It has a series of metal-rubber-metal washers, and if you leave the screw in the turntable, you don't need to mess with the washers.
Use two flat tools under both sides of the turntable to to pop it out.
The turntable slides down onto the bearing with some friction, but I've taken mine on and off 10 times and it still fits snugly.
That's basically it. My stepper has enough slack to maneuver it around without further disassembly.
To reinstall the turntable, the stepper side must go in first, in order for the turntable gears to align with the stepper gears.
Otherwise, the turntable will sit too high and not contact the stepper gear.
To reassemble, just follow these instructions in reverse.
