Ga door naar hoofdinhoud
Maingear Vector Laptop Screen Replacement
Wat je nodig hebt
    • pull off the black bezel around the deges
    • it is held on by double-sided tape. be careful not to break the bezel it is a somewhat thin plastic sheet.
    Vraag FixBot
    Voeg opmerking toe
  1. Gereedschap gebruikt in deze stap:
    • carefully pry up the bottom of the screen. there is double-sided tape holding it to the back.
    • pry on one side at a time slowly and once you can fit a pair of tweezers befind the screen grab the tape. when yo pull the tape it will come off like 3m command hooks
    • be careful not to rip the tape
    • the tape is in two vertical strips about an inch from the edge
    Vraag FixBot
    Voeg opmerking toe
    • the replacement screen is a lp156wfg(sp)(B2) on the maingear vector mg vctr001 1660ti from 2020
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. this is not a complete guide there is only enough info for you to know how to open it little steps are missing.
djluke mon
97 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 49
Altijd: 1,114
