Ga door naar hoofdinhoud
Main Click Buttons
Wat je nodig hebt
    1. Main Click Buttons, Click Buttons: stap 1, afbeelding 1 van 2 Main Click Buttons, Click Buttons: stap 1, afbeelding 2 van 2
      • Use a blue spudger to pry all 4 mouse feet off the bottom of the mouse.
      Vraag FixBot
      Voeg opmerking toe
    2. Main Click Buttons: stap 2, afbeelding 1 van 2 Main Click Buttons: stap 2, afbeelding 2 van 2
      • Use a #00 screwdriver (3x5mm) to unscrew all 6 screws from under the mouse feet.
      Vraag FixBot
      Voeg opmerking toe
    3. Main Click Buttons: stap 3, afbeelding 1 van 2 Main Click Buttons: stap 3, afbeelding 2 van 2
      • Use a blue spudger to open the bottom battery port.
      Vraag FixBot
      Voeg opmerking toe
    4. Main Click Buttons: stap 4, afbeelding 1 van 2 Main Click Buttons: stap 4, afbeelding 2 van 2
      • Lift the top of the mouse from the base of the mouse (separate mouse in half) to expose the internal hardware.
      Vraag FixBot
      Voeg opmerking toe
    5. Main Click Buttons: stap 5, afbeelding 1 van 3 Main Click Buttons: stap 5, afbeelding 2 van 3 Main Click Buttons: stap 5, afbeelding 3 van 3
      • Use pliers to grip and remove the black covers over the button — the black cover and the button, a small white plastic piece, should come off).
      Vraag FixBot
      Voeg opmerking toe
Conclusie
18 andere personen hebben deze handleiding voltooid.
6Gids Commentaar
how are you supposed to put the feet back?
Owen Yuen - Antwoord Deel
you have to buy new ones… i’m more concerned of using pliers to take the switch apart, when ideally you should desolder it and replace it with a proper omron switch (not made in china)
Erick Alonso Duque - Antwoord Deel
He is only removing the cover, not the whole button. But doing it with pliers is skipping that it has two clips, one at each end and you could damage the board just twisting and pulling
Russell Reeling - Antwoord Deel
Are the side buttons the same?
S I - Antwoord Deel
What do you do after step 5? And that copper spring looks wrong. It shouldn’t look like that. The correct positioning is this: https://community.pcgamingwiki.com/galle...
Nonalbert Noneinstein - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 172
Altijd: 25,699
