Ga door naar hoofdinhoud
Main Board Assembly Removal
Alleen vereisten
Deze gids is alleen bedoeld voor beginners! Deze gids maakt deel uit van een andere procedure en is niet bedoeld om alleen te worden gebruikt.
Wat je nodig hebt
  1. Main Board Assembly Removal, Before you begin: stap 1, afbeelding 1 van 3 Main Board Assembly Removal, Before you begin: stap 1, afbeelding 2 van 3 Main Board Assembly Removal, Before you begin: stap 1, afbeelding 3 van 3
    • Before starting your repair:
    • Shut down your PlayStation and unplug all cables and accessories.
    • Remove any stands supporting your console and lay it down so the right side is facing up.
  2. Main Board Assembly Removal, Remove the console covers: stap 2, afbeelding 1 van 3 Main Board Assembly Removal, Remove the console covers: stap 2, afbeelding 2 van 3 Main Board Assembly Removal, Remove the console covers: stap 2, afbeelding 3 van 3
    • Each console cover is secured with hooks along the rear edge and clips along the front edge.
    • To remove a cover, firmly pull up the front edge to release the clips.
    • You'll hear distinct "pops" as the clips release.
    • Remove the cover.
  3. Main Board Assembly Removal: stap 3, afbeelding 1 van 3 Main Board Assembly Removal: stap 3, afbeelding 2 van 3 Main Board Assembly Removal: stap 3, afbeelding 3 van 3
    • Use the same process to remove the three remaining covers.
    • To reinstall a cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the clips.
  4. Main Board Assembly Removal, Remove the power supply screws: stap 4, afbeelding 1 van 2 Main Board Assembly Removal, Remove the power supply screws: stap 4, afbeelding 2 van 2
    • Use a T8 Torx Security screwdriver to remove the two 21.5 mm‑long screws securing the power supply.
    • Flip your PlayStation over.
  5. Main Board Assembly Removal, Remove the expansion slot cover screw: stap 5, afbeelding 1 van 2 Main Board Assembly Removal, Remove the expansion slot cover screw: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    • Use a Phillips screwdriver to remove the 17.1 mm‑long screw securing the expansion slot cover.
  6. Main Board Assembly Removal, Remove the expansion slot cover: stap 6, afbeelding 1 van 3 Main Board Assembly Removal, Remove the expansion slot cover: stap 6, afbeelding 2 van 3 Main Board Assembly Removal, Remove the expansion slot cover: stap 6, afbeelding 3 van 3
    • Use your fingers to lift the expansion slot cover near the notch by the screw hole and remove it.
  7. Main Board Assembly Removal, Remove the fan cables cover: stap 7, afbeelding 1 van 3 Main Board Assembly Removal, Remove the fan cables cover: stap 7, afbeelding 2 van 3 Main Board Assembly Removal, Remove the fan cables cover: stap 7, afbeelding 3 van 3
    Tesa 61395 Tape
    $8.95
    • Use your fingers to remove the plastic cover hiding the fan cables connector.
    • The cover is secured with light adhesive.
    • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
  8. Main Board Assembly Removal, Free the fan cables: stap 8, afbeelding 1 van 2 Main Board Assembly Removal, Free the fan cables: stap 8, afbeelding 2 van 2
    • Gently pull the fan cables out from under their plastic clip on the frame.
  9. Main Board Assembly Removal, Disconnect the fan: stap 9, afbeelding 1 van 3 Main Board Assembly Removal, Disconnect the fan: stap 9, afbeelding 2 van 3 Main Board Assembly Removal, Disconnect the fan: stap 9, afbeelding 3 van 3
    • Firmly grip the fan cables' white connector head and pull it straight up and out of its socket.
    • If you're having trouble, grip the cables just above the connector head, and gently pull.
    • During reassembly, align the connector over its socket and push down on the edges with the flat end of a spudger until it slides fully into its socket.
  10. Main Board Assembly Removal, Remove the fan screws: stap 10, afbeelding 1 van 2 Main Board Assembly Removal, Remove the fan screws: stap 10, afbeelding 2 van 2
    • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
    • One 31.7 mm‑long screw
    • Two 21.5 mm‑long screws
    • One 11.5 mm‑long screw
  11. Main Board Assembly Removal, Remove the fan: stap 11, afbeelding 1 van 2 Main Board Assembly Removal, Remove the fan: stap 11, afbeelding 2 van 2
    • Use your fingers to grab the fan by its vents and lift it straight up to remove it.
    • During reassembly:
    • This is a good point to clean the fan. Use a clean cloth and some compressed air to remove any dust or dirt.
    • Insert the fan so its cables are near their connector.
  12. Main Board Assembly Removal, Peel up the tamper evident sticker: stap 12, afbeelding 1 van 2 Main Board Assembly Removal, Peel up the tamper evident sticker: stap 12, afbeelding 2 van 2
  13. Main Board Assembly Removal, Remove the fan grille: stap 13, afbeelding 1 van 3 Main Board Assembly Removal, Remove the fan grille: stap 13, afbeelding 2 van 3 Main Board Assembly Removal, Remove the fan grille: stap 13, afbeelding 3 van 3
    • Use your fingers to unclip and remove the plastic grille near the fan recess.
  14. Main Board Assembly Removal, Remove the right‑side inner shell screws: stap 14, afbeelding 1 van 2 Main Board Assembly Removal, Remove the right‑side inner shell screws: stap 14, afbeelding 2 van 2
    • Use a T8 Torx Security screwdriver to remove the 10 screws securing the right‑side inner shell:
    • Four 18.8 mm‑long screws
    • Two 18.6 mm‑long screws
    • Four 31.7 mm‑long screws
  15. Main Board Assembly Removal, Remove the right‑side inner shell: stap 15, afbeelding 1 van 2 Main Board Assembly Removal, Remove the right‑side inner shell: stap 15, afbeelding 2 van 2
    • Lift the right‑side inner shell straight up and remove it.
  16. Main Board Assembly Removal, Disconnect the CMOS board: stap 16, afbeelding 1 van 3 Main Board Assembly Removal, Disconnect the CMOS board: stap 16, afbeelding 2 van 3 Main Board Assembly Removal, Disconnect the CMOS board: stap 16, afbeelding 3 van 3
    • Use a pair of angled tweezers to firmly grip the sides of the CMOS board connector, holding the tweezers as close to the connector as possible to get a good grip.
    • Pull the connector straight up and out of its socket to disconnect it.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
  17. Main Board Assembly Removal, Remove the CMOS board: stap 17, afbeelding 1 van 3 Main Board Assembly Removal, Remove the CMOS board: stap 17, afbeelding 2 van 3 Main Board Assembly Removal, Remove the CMOS board: stap 17, afbeelding 3 van 3
    • Use your fingers to lift the CMOS board off the small metal nubs and pull it toward the center of your console to remove it.
    • If your new board doesn't come with a cable, transfer the original cable to your replacement board.
  18. Main Board Assembly Removal, Disconnect the antenna cables: stap 18, afbeelding 1 van 3 Main Board Assembly Removal, Disconnect the antenna cables: stap 18, afbeelding 2 van 3 Main Board Assembly Removal, Disconnect the antenna cables: stap 18, afbeelding 3 van 3
    • Insert a spudger under the metal neck of one of the antenna cable's coaxial connectors and lift straight up to disconnect it.
    • Repeat the process to disconnect the other antenna cable.
    • Use the markings on the board to reconnect the antenna cables to the correct sockets—connect the blue cable to the socket marked RB and the white cable to the one marked RW.
    • To reconnect a cable, hold the metal connector head over its socket and press down with the flat end of a spudger until the connector snaps into place. Don't try to force the connector into place. If you're having trouble, reposition the connector and try again.
  19. Main Board Assembly Removal: stap 19, afbeelding 1 van 3 Main Board Assembly Removal: stap 19, afbeelding 2 van 3 Main Board Assembly Removal: stap 19, afbeelding 3 van 3
    • Use the point of a spudger to flip up the small piece of white tape securing the antenna cables to the metal shield.
  20. Main Board Assembly Removal, Move the antenna cables: stap 20, afbeelding 1 van 3 Main Board Assembly Removal, Move the antenna cables: stap 20, afbeelding 2 van 3 Main Board Assembly Removal, Move the antenna cables: stap 20, afbeelding 3 van 3
    • Use your fingers to de‑route the antenna cables from their clips on the metal shield.
    • Move the antenna cables over the side of your PlayStation so they're out of the way.
  21. Main Board Assembly Removal, Pry up the heat sink: stap 21, afbeelding 1 van 3 Main Board Assembly Removal, Pry up the heat sink: stap 21, afbeelding 2 van 3 Main Board Assembly Removal, Pry up the heat sink: stap 21, afbeelding 3 van 3
    • Thermal paste bonds the bottom heat sink fins (closest to the power button) to the metal shield. Depending on the age of your device and condition of the thermal paste, separating the heat sink may take some force.
    • Insert the flat end of a spudger under the bend in the copper pipes, near the heat sink's bottom edge.
    • Use your spudger to pry up the heat sink, applying steady pressure to separate it from the thermal paste.
    • If the heat sink doesn't fully separate, use your spudger to pry up the bottom edge on the other side of the metal fins.
  22. Main Board Assembly Removal, Remove the heat sink: stap 22, afbeelding 1 van 2 Main Board Assembly Removal, Remove the heat sink: stap 22, afbeelding 2 van 2
    • Grip the heat sink by its copper pipes and remove it.
    • Don't grip the sharp, metal fins on the heat sink.
    • Before removing any of the old thermal paste, note the location and quantity of thermal paste on the metal shield. This way you'll know how much to use when replacing it.
    • Use the flat end of a spudger to scrape up and remove as much of the old thermal paste as possible.
    • Remove all the remaining thermal paste and its residue with high‑concentration (>90%) isopropyl alcohol and a microfiber cloth.
    • Apply new thermal paste where the old paste was.
    • Firmly push the heat sink into place.
  23. Main Board Assembly Removal, Remove the main board assembly screws: stap 23, afbeelding 1 van 3 Main Board Assembly Removal, Remove the main board assembly screws: stap 23, afbeelding 2 van 3 Main Board Assembly Removal, Remove the main board assembly screws: stap 23, afbeelding 3 van 3
    • Use a T8 Torx Security screwdriver to remove the six screws:
    • One 11.5 mm‑long black screw securing the main board assembly
    • One 28.7 mm‑long screw securing the interconnect cable cover
    • Four 7.5 mm‑long screws securing the interconnect cable cover
  24. Main Board Assembly Removal, Remove the interconnect cable cover: stap 24, afbeelding 1 van 2 Main Board Assembly Removal, Remove the interconnect cable cover: stap 24, afbeelding 2 van 2
    • Remove the interconnect cable cover.
  25. Main Board Assembly Removal, Disconnect the interconnect cable: stap 25, afbeelding 1 van 3 Main Board Assembly Removal, Disconnect the interconnect cable: stap 25, afbeelding 2 van 3 Main Board Assembly Removal, Disconnect the interconnect cable: stap 25, afbeelding 3 van 3
    • Use the flat end of a spudger to push down the metal bar on the interconnect cable socket.
    • With the metal bar held down, use your fingers or tweezers to grip the plastic pull tab and slide the cable straight out of its socket.
    • During reassembly, insert the interconnect cable into the socket until it snaps into place.
  26. Main Board Assembly Removal, Lift the main board assembly: stap 26, afbeelding 1 van 2 Main Board Assembly Removal, Lift the main board assembly: stap 26, afbeelding 2 van 2
    • The power supply is connected to the bottom of the main board assembly by metal prongs that plug into the bottom left corner.
    • Lift the bottom left corner of the main board assembly off its gray plastic post. Keep the assembly lifted for the next step.
    • Your PlayStation's plastic housing will likely flex while lifting the assembly.
  27. Main Board Assembly Removal, Detach the power supply: stap 27, afbeelding 1 van 3 Main Board Assembly Removal, Detach the power supply: stap 27, afbeelding 2 van 3 Main Board Assembly Removal, Detach the power supply: stap 27, afbeelding 3 van 3
    • Keep the main board assembly raised with one hand.
    • With your free hand, insert your finger between the assembly and power supply.
    • Push down on the power supply and lift the assembly to separate them.
    • It'll take a significant amount of force to separate the two.
    • During reassembly, press down firmly on the bottom left corner of the main board assembly to fully connect it to the power supply.
  28. Main Board Assembly Removal, Remove the main board assembly: stap 28, afbeelding 1 van 3 Main Board Assembly Removal, Remove the main board assembly: stap 28, afbeelding 2 van 3 Main Board Assembly Removal, Remove the main board assembly: stap 28, afbeelding 3 van 3
    • Do not grab the main board assembly by the copper heat pipes or its fins, as they can easily be damaged.
    • Firmly secure the plastic housing with one hand.
    • With your free hand, grab the upper edge of the main board assembly and lift it out of the plastic housing.
    • Make sure the interconnect cable doesn't get stuck under the main board assembly when lowering it into place.
    • Lower the assembly into its recess so its prongs go into their socket on the power supply and the two cutouts go over their alignment posts.
Eindstreep
Spencer Day
163.615 Reputatie
1.043 handleidingen geschreven
iFixit Lid van iFixit
Staff
124 Leden
24.238 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 77
