Ga door naar hoofdinhoud
Magic Bullet NutriBullet Rubber Gasket Replacement
Wat je nodig hebt
    1. Magic Bullet NutriBullet Rubber Gasket Replacement, Rubber Gasket: stap 1, afbeelding 1 van 1
      • Separate the blending blade lid from the cup.
      Vraag FixBot
      Voeg opmerking toe
    2. Magic Bullet NutriBullet Rubber Gasket Replacement: stap 2, afbeelding 1 van 2 Magic Bullet NutriBullet Rubber Gasket Replacement: stap 2, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Using tweezers, grab the gasket at the indented lip which is located on the side of the blending blade.
      • Slowly pry the rubber gasket up.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Geary Yu
1.277 Reputatie
3 handleidingen geschreven
Cal Poly, Team 19-8, Maness Winter 2015 Lid van Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Leden
19 handleidingen geschreven
11Gids Commentaar
The trouble is, this process doesn't work in reverse order as the gasket keeps popping up where you are not applying the pressure. You could do this all day and I'm sure it would be great therapy for OCD.
lizzywade888 - Antwoord Deel
I want to replace the rubber gasket. My trouble is I can't find a gasket that states it will fit this model. magic Bullet NUTRIBULLET model number NB-WL007-02 Can you tell me where to purchase this? Thanks!
Marcia Sikes
today_first@cox.net
todayfirst - Antwoord Deel
My understanding is that if it's leaking all the way into the base and not out the sides, it's likely not the main gasket (a faulty one of these would probably cause it to leak out the sides). This is a really good video that explains how to remove the blade and replace the washers that act as gaskets to stop liquid from dripping straight through the center/blade area.
https://www.youtube.com/watch?v=n0fiNRwh...
Tracy Hamilton - Antwoord Deel
Thanks a lot.
Kayla Martin - Antwoord Deel
lizzywad is correct. The %#*@ thing wont stay in, it keeps popping out.  What else can be done?
deborah blair - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 176
Altijd: 38,395
