Ga door naar hoofdinhoud
Magic Bullet NutriBullet Outside Casing Replacement
Wat je nodig hebt
  1. Magic Bullet NutriBullet Outside Casing Replacement, Curve Base: stap 1, afbeelding 1 van 1
    • Unplug the device from the wall and turn the powerbase upside down.
    Vraag FixBot
    Voeg opmerking toe
  2. Magic Bullet NutriBullet Outside Casing Replacement: stap 2, afbeelding 1 van 2 Magic Bullet NutriBullet Outside Casing Replacement: stap 2, afbeelding 2 van 2
    • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
    Vraag FixBot
    Voeg opmerking toe
  3. Magic Bullet NutriBullet Outside Casing Replacement: stap 3, afbeelding 1 van 1
    • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
    • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
    Vraag FixBot
    Voeg opmerking toe
  4. Magic Bullet NutriBullet Outside Casing Replacement: stap 4, afbeelding 1 van 1
    • Lift the power cord to remove it from the side slot on the curved base.
    Vraag FixBot
    Voeg opmerking toe
  5. Magic Bullet NutriBullet Outside Casing Replacement: stap 5, afbeelding 1 van 2 Magic Bullet NutriBullet Outside Casing Replacement: stap 5, afbeelding 2 van 2
    • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
    • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
    Vraag FixBot
    Voeg opmerking toe
  6. Magic Bullet NutriBullet Outside Casing Replacement: stap 6, afbeelding 1 van 1
    • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
    Vraag FixBot
    Voeg opmerking toe
  7. Magic Bullet NutriBullet Outside Casing Replacement: stap 7, afbeelding 1 van 1
    • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
    Vraag FixBot
    Voeg opmerking toe
  8. Magic Bullet NutriBullet Outside Casing Replacement, Outside Casing: stap 8, afbeelding 1 van 1
    • Wiggle the outside casing upward until it separates from the powerbase.
    • Hold the ring at the bottom of the powerbase to receive a better grip.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Angela Wong
1.177 Reputatie
3 handleidingen geschreven
Cal Poly, Team 19-8, Maness Winter 2015 Lid van Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Leden
13 handleidingen geschreven
4Gids Commentaar
Ok so what happens after Step 8 of pulling the Nutribullet apart? Did I miss something?? Now I have my Nutribullet in pieces on the benchtop. Now what??
Nicole Corse-Scott - Antwoord Deel
Same problem. I can't get the drive gear on the top loose which I assume will actual give me access to the wiring. I am guessing it is a pressure fit but I can't get anything under it to pry it loose. If it is a screw attachment don't want to break it. Help.
rjurgena - Antwoord Deel
So what happens next? What is one suppose to do? Stupid help, I would say
Mary Johnson - Antwoord Deel
I tried step number 8 and the outside casing still won't slide off. What do I do now?
Euclid Taylor - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 72
Altijd: 8,721
