Ga door naar hoofdinhoud
Magic Bullet MB1001B Power Cord Replacement
Wat je nodig hebt
  1. Magic Bullet MB1001B Power Cord Replacement, Power Cord: stap 1, afbeelding 1 van 1
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
    Vraag FixBot
    Voeg opmerking toe
  2. Magic Bullet MB1001B Power Cord Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. Magic Bullet MB1001B Power Cord Replacement: stap 3, afbeelding 1 van 1
    • Remove the black base plate.
    Vraag FixBot
    Voeg opmerking toe
  4. Magic Bullet MB1001B Power Cord Replacement: stap 4, afbeelding 1 van 1
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. Magic Bullet MB1001B Power Cord Replacement: stap 5, afbeelding 1 van 1
    • Remove the white plastic cable guide.
    Vraag FixBot
    Voeg opmerking toe
  6. Magic Bullet MB1001B Power Cord Replacement: stap 6, afbeelding 1 van 1
    • Remove the two crimp caps from the end of the wires.
    • You will need to purchase new crimp caps and use pliers to crimp the new crimp caps on the connected wires during reassembly.
    Vraag FixBot
    Voeg opmerking toe
  7. Magic Bullet MB1001B Power Cord Replacement: stap 7, afbeelding 1 van 1
    • Separate the black wires of the power cord from the red wires on the Magic Bullet base.
    • Be sure to mark which wires are connected before separating them to ensure that they are properly reconnected during reassembly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Bridget Carr
266 Reputatie
1 Handleiding geschreven
Cal Poly, Team 12-13, Maness Fall 2015 Lid van Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Leden
8 handleidingen geschreven
2Gids Commentaar
I accidentally burnt through my power cord. What type of power cord do I need to replace it?
virginia.cooke - Antwoord Deel
Where do we get a new power cord, and if that does not work, what do we do next?
davidcohnkettlebells - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 2,939
