Ga door naar hoofdinhoud
Magic Bullet MB1001B Casing Replacement
Wat je nodig hebt
    1. Magic Bullet MB1001B Casing Replacement, Base Gear: stap 1, afbeelding 1 van 3 Magic Bullet MB1001B Casing Replacement, Base Gear: stap 1, afbeelding 2 van 3 Magic Bullet MB1001B Casing Replacement, Base Gear: stap 1, afbeelding 3 van 3
      • Use pliers to grip the gear inside of the top of the device.
      • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
      • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
      • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
      Vraag FixBot
      Voeg opmerking toe
    1. Magic Bullet MB1001B Casing Replacement, Casing: stap 2, afbeelding 1 van 1
      • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
      Vraag FixBot
      Voeg opmerking toe
    2. Magic Bullet MB1001B Casing Replacement: stap 3, afbeelding 1 van 1
      • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Magic Bullet MB1001B Casing Replacement: stap 4, afbeelding 1 van 1
      • Remove the black base plate.
      Vraag FixBot
      Voeg opmerking toe
    4. Magic Bullet MB1001B Casing Replacement: stap 5, afbeelding 1 van 1
      • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    5. Magic Bullet MB1001B Casing Replacement: stap 6, afbeelding 1 van 1
      • Remove the white plastic cable guide.
      Vraag FixBot
      Voeg opmerking toe
    6. Magic Bullet MB1001B Casing Replacement: stap 7, afbeelding 1 van 1
      • Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    7. Magic Bullet MB1001B Casing Replacement: stap 8, afbeelding 1 van 1
      • Remove the black base.
      Vraag FixBot
      Voeg opmerking toe
    8. Magic Bullet MB1001B Casing Replacement: stap 9, afbeelding 1 van 1
      • Remove the three white rubber spacers with the spudger.
      Vraag FixBot
      Voeg opmerking toe
    9. Magic Bullet MB1001B Casing Replacement: stap 10, afbeelding 1 van 1
      • Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    10. Magic Bullet MB1001B Casing Replacement: stap 11, afbeelding 1 van 1
      • Remove the motor.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kelly McGartland
555 Reputatie
2 handleidingen geschreven
Cal Poly, Team 12-13, Maness Fall 2015 Lid van Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Leden
13 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 37
Altijd: 2,155
