Ga door naar hoofdinhoud
Magic Bullet MB1001B Activator Replacement
Wat je nodig hebt
  1. Magic Bullet MB1001B Activator Replacement, Base Gear: stap 1, afbeelding 1 van 3 Magic Bullet MB1001B Activator Replacement, Base Gear: stap 1, afbeelding 2 van 3 Magic Bullet MB1001B Activator Replacement, Base Gear: stap 1, afbeelding 3 van 3
    • Use pliers to grip the gear inside of the top of the device.
    • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
    • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
    • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
    Vraag FixBot
    Voeg opmerking toe
  2. Magic Bullet MB1001B Activator Replacement, Casing: stap 2, afbeelding 1 van 1
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
    Vraag FixBot
    Voeg opmerking toe
  3. Magic Bullet MB1001B Activator Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Magic Bullet MB1001B Activator Replacement: stap 4, afbeelding 1 van 1
    • Remove the black base plate.
    Vraag FixBot
    Voeg opmerking toe
  5. Magic Bullet MB1001B Activator Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  6. Magic Bullet MB1001B Activator Replacement: stap 6, afbeelding 1 van 1
    • Remove the white plastic cable guide.
    Vraag FixBot
    Voeg opmerking toe
  7. Magic Bullet MB1001B Activator Replacement: stap 7, afbeelding 1 van 1
    • Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  8. Magic Bullet MB1001B Activator Replacement: stap 8, afbeelding 1 van 1
    • Remove the black base.
    Vraag FixBot
    Voeg opmerking toe
  9. Magic Bullet MB1001B Activator Replacement: stap 9, afbeelding 1 van 1
    • Remove the three white rubber spacers with the spudger.
    Vraag FixBot
    Voeg opmerking toe
  10. Magic Bullet MB1001B Activator Replacement: stap 10, afbeelding 1 van 1
    • Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  11. Magic Bullet MB1001B Activator Replacement: stap 11, afbeelding 1 van 1
    • Remove the motor.
    Vraag FixBot
    Voeg opmerking toe
  12. Magic Bullet MB1001B Activator Replacement, Activator: stap 12, afbeelding 1 van 2 Magic Bullet MB1001B Activator Replacement, Activator: stap 12, afbeelding 2 van 2
    • Wedge a flathead screwdriver in between the casing and white plastic activator.
    • Pry the white plastic activators from the casing as needed.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Aubree Duran
387 Reputatie
1 Handleiding geschreven
Cal Poly, Team 12-13, Maness Fall 2015 Lid van Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Leden
8 handleidingen geschreven
4Gids Commentaar
You gotta be kidding me?
marcomolinero72 - Antwoord Deel
Right. Steps on how to fix their faulty machine. And worse. Selling you the tools to do it for only 29.99!
Del - Antwoord Deel
Where would you get replacement activators or spring beneath these? How much would that cost?
Spartan 1293 - Antwoord Deel
Oh, my gosh! I’ll just throw this thing away and use my blender!
txberta - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 61
Altijd: 10,053
