Ga door naar hoofdinhoud
Mad Catz Dual Force 2 Pro Vibration Motors Replacement
Wat je nodig hebt
  1. Mad Catz Dual Force 2 Pro Vibration Motors Replacement, Remove Cover: stap 1, afbeelding 1 van 1
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: stap 2, afbeelding 1 van 1
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 7 mm screws on the closest circuit board.
  4. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: stap 4, afbeelding 1 van 2 Mad Catz Dual Force 2 Pro Vibration Motors Replacement: stap 4, afbeelding 2 van 2
    • Grip the sides of the motor you wish to replace and lift up.
    • Be careful not to tear the wires that connect the motors to the motherboard.
  5. Mad Catz Dual Force 2 Pro Vibration Motors Replacement, Remove the Screw: stap 5, afbeelding 1 van 1
    • Use a soldering iron to de-solder both vibration motor wires from the motherboard.
    • If you do not know how to solder, see the soldering guide for instructions.
    • The positive (red) wire connects nearest the edge of the motherboard.
    • When soldering on circuit boards, be sure not to overheat the connection as permanent damage may result.
  6. Mad Catz Dual Force 2 Pro Vibration Motors Replacement: stap 6, afbeelding 1 van 1
    • If needed, repeat the last two steps for the other vibration motors.
Conclusie
Alexander Coyne
658 Reputatie
5 handleidingen geschreven
USF Tampa, Team 7-2, Remmell Winter 2015 Lid van USF Tampa, Team 7-2, Remmell Winter 2015
USFT-REMMELL-W15S7G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 12
Altijd: 329
