Ga door naar hoofdinhoud
Macintosh Powerbook 5300cs RAM Replacement
Wat je nodig hebt
    1. Macintosh Powerbook 5300cs RAM Replacement, Battery: stap 1, afbeelding 1 van 1
      • The battery compartment is located in the front-right side of the laptop.
      Vraag FixBot
      Voeg opmerking toe
    2. Macintosh Powerbook 5300cs RAM Replacement: stap 2, afbeelding 1 van 1
      • To insert the battery, gently slide it into the compartment until it clicks in place.
      • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
      Vraag FixBot
      Voeg opmerking toe
    1. Macintosh Powerbook 5300cs RAM Replacement, Keyboard: stap 3, afbeelding 1 van 1
      • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
      Vraag FixBot
      Voeg opmerking toe
    2. Macintosh Powerbook 5300cs RAM Replacement: stap 4, afbeelding 1 van 2 Macintosh Powerbook 5300cs RAM Replacement: stap 4, afbeelding 2 van 2
      • Carefully pull up on the front of the keyboard to pop it out from the case.
      • Then slide the back out so the keyboard becomes nearly free.
      Vraag FixBot
      Voeg opmerking toe
    3. Macintosh Powerbook 5300cs RAM Replacement: stap 5, afbeelding 1 van 3 Macintosh Powerbook 5300cs RAM Replacement: stap 5, afbeelding 2 van 3 Macintosh Powerbook 5300cs RAM Replacement: stap 5, afbeelding 3 van 3
      • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
      • Pull the keyboard out and repair or replace as needed.
      Vraag FixBot
      Voeg opmerking toe
    1. Macintosh Powerbook 5300cs RAM Replacement, RAM: stap 6, afbeelding 1 van 3 Macintosh Powerbook 5300cs RAM Replacement, RAM: stap 6, afbeelding 2 van 3 Macintosh Powerbook 5300cs RAM Replacement, RAM: stap 6, afbeelding 3 van 3
      • Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Ronan
72 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-1, Regan Fall 2011 Lid van Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Leden
40 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 29
Altijd: 1,352
