Ga door naar hoofdinhoud
Macintosh PowerBook 165c Display Replacement
Wat je nodig hebt
    1. Macintosh PowerBook 165c Display Replacement, Display: stap 1, afbeelding 1 van 1
      • Orientate the computer right side up and open the display case to reveal the display.
      • Use a plastic opening tool to remove the two small plastic plugs located on the display case just below the display.
      Vraag FixBot
      Voeg opmerking toe
    2. Macintosh PowerBook 165c Display Replacement: stap 2, afbeelding 1 van 1
      • Use a T8 torx screwdriver to remove the two, 7.7mm long screws that were revealed by removing the plastic plugs.
      • Twist counterclockwise to remove the screw.
      • Caution: Once the screws are removed, the display is only held by two screws. Handle delicately.
      Vraag FixBot
      Voeg opmerking toe
    3. Macintosh PowerBook 165c Display Replacement: stap 3, afbeelding 1 van 1
      • Grip the two bottom corners of the plastic display cover and gently pull towards yourself so that the display cover rotates about the top of the display case.
      • The display cover should release from top.
      • Remove the display case.
      Vraag FixBot
      Voeg opmerking toe
    4. Macintosh PowerBook 165c Display Replacement: stap 4, afbeelding 1 van 1
      • Locate the black connector on the right of the display. The connector can be identified by the pink, light blue, and white wires protruding from its side.
      • Remove the black connector from the circuit board by pulling it away from its adapter.
      Vraag FixBot
      Voeg opmerking toe
    5. Macintosh PowerBook 165c Display Replacement: stap 5, afbeelding 1 van 1
      • Using a T8 torx screwdriver, remove the four, 10.8mm long screws from the corners of the display.
      • Caution: The display is no longer supported and must be handled with care.
      Vraag FixBot
      Voeg opmerking toe
    6. Macintosh PowerBook 165c Display Replacement: stap 6, afbeelding 1 van 1
      • Carefully tilt the display downwards and rest it on the keyboard.
      Vraag FixBot
      Voeg opmerking toe
    7. Macintosh PowerBook 165c Display Replacement: stap 7, afbeelding 1 van 3 Macintosh PowerBook 165c Display Replacement: stap 7, afbeelding 2 van 3 Macintosh PowerBook 165c Display Replacement: stap 7, afbeelding 3 van 3
      • Locate the orange ribbon cable on the back of the display.
      • Open the white tab fastener by pulling it outward.
      • Remove the orange ribbon cable by gently pulling it away from the opened tab fastener.
      • The display is now free.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jason
110 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-3, Regan Fall 2011 Lid van Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
4 Leden
95 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 50
Altijd: 3,008
