Ga door naar hoofdinhoud
Macbook Pro 14" 2023 Antenna Bar Replacement
Wat je nodig hebt
  1. Macbook Pro 14" 2023 Antenna Bar Replacement, Unfasten the lower case: stap 1, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement, Unfasten the lower case: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    Koop
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.3 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. Macbook Pro 14" 2023 Antenna Bar Replacement, Unclip the lower case: stap 2, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement, Unclip the lower case: stap 2, afbeelding 2 van 2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. Macbook Pro 14" 2023 Antenna Bar Replacement, Release the right clips: stap 3, afbeelding 1 van 3 Macbook Pro 14" 2023 Antenna Bar Replacement, Release the right clips: stap 3, afbeelding 2 van 3 Macbook Pro 14" 2023 Antenna Bar Replacement, Release the right clips: stap 3, afbeelding 3 van 3
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. Macbook Pro 14" 2023 Antenna Bar Replacement, Release the left clips: stap 4, afbeelding 1 van 3 Macbook Pro 14" 2023 Antenna Bar Replacement, Release the left clips: stap 4, afbeelding 2 van 3 Macbook Pro 14" 2023 Antenna Bar Replacement, Release the left clips: stap 4, afbeelding 3 van 3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. Macbook Pro 14" 2023 Antenna Bar Replacement, Release the sliding clips: stap 5, afbeelding 1 van 3 Macbook Pro 14" 2023 Antenna Bar Replacement, Release the sliding clips: stap 5, afbeelding 2 van 3 Macbook Pro 14" 2023 Antenna Bar Replacement, Release the sliding clips: stap 5, afbeelding 3 van 3
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  6. Macbook Pro 14" 2023 Antenna Bar Replacement, Remove the lower case: stap 6, afbeelding 1 van 3 Macbook Pro 14" 2023 Antenna Bar Replacement, Remove the lower case: stap 6, afbeelding 2 van 3 Macbook Pro 14" 2023 Antenna Bar Replacement, Remove the lower case: stap 6, afbeelding 3 van 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  7. Macbook Pro 14" 2023 Antenna Bar Replacement, Disconnect the battery board: stap 7, afbeelding 1 van 3 Macbook Pro 14" 2023 Antenna Bar Replacement, Disconnect the battery board: stap 7, afbeelding 2 van 3 Macbook Pro 14" 2023 Antenna Bar Replacement, Disconnect the battery board: stap 7, afbeelding 3 van 3
    • Peel back any tape covering the battery board data cable connector on the logic board.
  8. Macbook Pro 14" 2023 Antenna Bar Replacement: stap 8, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement: stap 8, afbeelding 2 van 2
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  9. Macbook Pro 14" 2023 Antenna Bar Replacement: stap 9, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement: stap 9, afbeelding 2 van 2
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. Macbook Pro 14" 2023 Antenna Bar Replacement, Unfasten the trackpad cable bracket: stap 10, afbeelding 1 van 1
    • While your MacBook uses some Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to avoid stripping.
    • Use a T3 Torx driver to remove the two 2.1 mm‑long 3IP Torx Plus screws securing the trackpad cable bracket to the logic board.
  11. Macbook Pro 14" 2023 Antenna Bar Replacement, Remove the trackpad cable bracket: stap 11, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement, Remove the trackpad cable bracket: stap 11, afbeelding 2 van 2
    Koop
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. Macbook Pro 14" 2023 Antenna Bar Replacement, Disconnect the trackpad cable: stap 12, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement, Disconnect the trackpad cable: stap 12, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. Macbook Pro 14" 2023 Antenna Bar Replacement, Reposition the trackpad cable: stap 13, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement, Reposition the trackpad cable: stap 13, afbeelding 2 van 2
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. Macbook Pro 14" 2023 Antenna Bar Replacement, Disconnect the battery board: stap 14, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement, Disconnect the battery board: stap 14, afbeelding 2 van 2
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. Macbook Pro 14" 2023 Antenna Bar Replacement: stap 15, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement: stap 15, afbeelding 2 van 2
  16. Macbook Pro 14" 2023 Antenna Bar Replacement: stap 16, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement: stap 16, afbeelding 2 van 2
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  17. Macbook Pro 14" 2023 Antenna Bar Replacement, Remove the data cable: stap 17, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement, Remove the data cable: stap 17, afbeelding 2 van 2
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  18. Macbook Pro 14" 2023 Antenna Bar Replacement, Unfasten the battery connector: stap 18, afbeelding 1 van 1
    • Use a T5 Torx driver to remove the 3.8 mm 5IP Torx Plus wide-head screw securing the battery power connector.
  19. Macbook Pro 14" 2023 Antenna Bar Replacement, Disconnect the battery connector: stap 19, afbeelding 1 van 3 Macbook Pro 14" 2023 Antenna Bar Replacement, Disconnect the battery connector: stap 19, afbeelding 2 van 3 Macbook Pro 14" 2023 Antenna Bar Replacement, Disconnect the battery connector: stap 19, afbeelding 3 van 3
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
  20. Macbook Pro 14" 2023 Antenna Bar Replacement, Unfasten the antenna bar's connector bracket: stap 20, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement, Unfasten the antenna bar's connector bracket: stap 20, afbeelding 2 van 2
    • Use your T3 Torx driver to remove the three 2.1 mm-long 3IP Torx Plus screws securing the antenna connector cover and bracket.
  21. Macbook Pro 14" 2023 Antenna Bar Replacement: stap 21, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement: stap 21, afbeelding 2 van 2
    Koop
    • Use tweezers, or your fingers, to remove the cover on top of the antenna bar's coaxial cables.
  22. Macbook Pro 14" 2023 Antenna Bar Replacement, Disconnect the antenna bar: stap 22, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement, Disconnect the antenna bar: stap 22, afbeelding 2 van 2
    • Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
    • Repeat for the two other cables.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  23. Macbook Pro 14" 2023 Antenna Bar Replacement, Unfasten the antenna bar: stap 23, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement, Unfasten the antenna bar: stap 23, afbeelding 2 van 2
    • Use a T5 Torx screwdriver to remove the six 5IP Torx Plus screws securing the antenna bar to the frame:
    • Two 7.5 mm screws
    • Four 3.2 mm screws
    • Use a P2 Pentalobe driver to remove the nine 1.5 mm screws securing the antenna bar to the frame.
    • These screws strip very easily; use constant downward pressure and work slowly when you loosen these.
  24. Macbook Pro 14" 2023 Antenna Bar Replacement, Remove the antenna bar: stap 24, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement, Remove the antenna bar: stap 24, afbeelding 2 van 2
    • Insert the tip of a spudger between the antenna bar and the frame.
    • Pry up with the spudger to separate the antenna bar from the frame.
  25. Macbook Pro 14" 2023 Antenna Bar Replacement: stap 25, afbeelding 1 van 2 Macbook Pro 14" 2023 Antenna Bar Replacement: stap 25, afbeelding 2 van 2
    • Pull the antenna bar straight up and out of the frame to remove it.
Conclusie
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2023 Answers community for help.
Chayton Ritter
18.513 Reputatie
102 handleidingen geschreven
Guide Team Lid van Guide Team
Staff
6 Leden
7.830 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 38
Altijd: 966
