Ga door naar hoofdinhoud
MacBook Pro 16" Late 2023 Screen Replacement
Wat je nodig hebt
  1. MacBook Pro 16" Late 2023 Screen Replacement, Prepare your MacBook for disassembly: stap 1, afbeelding 1 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Prepare your MacBook for disassembly: stap 1, afbeelding 2 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Prepare your MacBook for disassembly: stap 1, afbeelding 3 van 3
    • Allow your MacBook's battery to drain below 10% before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Fully shut down your MacBook, close the lid, and flip it over. Keep the lid closed until you've physically disconnected the battery.
    • Unplug the MagSafe cable and any accessories connected to your MacBook.
  2. MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the lower case: stap 2, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the lower case: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.2 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 16" Late 2023 Screen Replacement, Unclip the lower case: stap 3, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Unclip the lower case: stap 3, afbeelding 2 van 2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  4. MacBook Pro 16" Late 2023 Screen Replacement, Release the lower case's right clips: stap 4, afbeelding 1 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Release the lower case's right clips: stap 4, afbeelding 2 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Release the lower case's right clips: stap 4, afbeelding 3 van 3
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  5. MacBook Pro 16" Late 2023 Screen Replacement, Release the rear cover's left clips: stap 5, afbeelding 1 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Release the rear cover's left clips: stap 5, afbeelding 2 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Release the rear cover's left clips: stap 5, afbeelding 3 van 3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  6. MacBook Pro 16" Late 2023 Screen Replacement, Release the sliding clips: stap 6, afbeelding 1 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Release the sliding clips: stap 6, afbeelding 2 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Release the sliding clips: stap 6, afbeelding 3 van 3
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  7. MacBook Pro 16" Late 2023 Screen Replacement, Remove the lower case: stap 7, afbeelding 1 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Remove the lower case: stap 7, afbeelding 2 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Remove the lower case: stap 7, afbeelding 3 van 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the screen hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  8. MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the battery board: stap 8, afbeelding 1 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the battery board: stap 8, afbeelding 2 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the battery board: stap 8, afbeelding 3 van 3
    • Peel back any tape covering the battery board data cable connector on the logic board.
  9. MacBook Pro 16" Late 2023 Screen Replacement: stap 9, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement: stap 9, afbeelding 2 van 2
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  10. MacBook Pro 16" Late 2023 Screen Replacement: stap 10, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement: stap 10, afbeelding 2 van 2
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  11. MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the trackpad cable bracket: stap 11, afbeelding 1 van 1
    • Use a 3IP Torx Plus driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
  12. MacBook Pro 16" Late 2023 Screen Replacement, Remove the trackpad cable bracket: stap 12, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Remove the trackpad cable bracket: stap 12, afbeelding 2 van 2
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  13. MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the trackpad cable: stap 13, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the trackpad cable: stap 13, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector from the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  14. MacBook Pro 16" Late 2023 Screen Replacement, Reposition the trackpad cable: stap 14, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Reposition the trackpad cable: stap 14, afbeelding 2 van 2
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  15. MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the battery board: stap 15, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the battery board: stap 15, afbeelding 2 van 2
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  16. MacBook Pro 16" Late 2023 Screen Replacement: stap 16, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement: stap 16, afbeelding 2 van 2
  17. MacBook Pro 16" Late 2023 Screen Replacement: stap 17, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement: stap 17, afbeelding 2 van 2
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  18. MacBook Pro 16" Late 2023 Screen Replacement, Remove the data cable: stap 18, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Remove the data cable: stap 18, afbeelding 2 van 2
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  19. MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the battery connector: stap 19, afbeelding 1 van 1
    • Use a 5IP Torx Plus driver to remove the 4 mm pancake screw securing the battery power connector.
  20. MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the battery connector: stap 20, afbeelding 1 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the battery connector: stap 20, afbeelding 2 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the battery connector: stap 20, afbeelding 3 van 3
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
  21. MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the antenna bar's connector bracket: stap 21, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the antenna bar's connector bracket: stap 21, afbeelding 2 van 2
    • Use a 3IP Torx Plus screwdriver to remove the three 2.1 mm screws securing the antenna board bracket and coaxial cable cover to the frame.
  22. MacBook Pro 16" Late 2023 Screen Replacement: stap 22, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement: stap 22, afbeelding 2 van 2
    • Use tweezers, or your fingers, to remove the cover on top of the antenna bar's coaxial cables.
  23. MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the antenna bar: stap 23, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the antenna bar: stap 23, afbeelding 2 van 2
    • Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
    • Repeat for the two other cables.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  24. MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the antenna bar: stap 24, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the antenna bar: stap 24, afbeelding 2 van 2
    • Use a 5IP Torx Plus screwdriver to remove the six screws securing the antenna bar to the frame:
    • Two 7.5 mm screws
    • Four 3 mm screws
    • Use a P2 Pentalobe driver to remove the nine 1.5 mm screws securing the antenna bar to the frame.
    • These screws strip very easily; use constant downward pressure and work slowly when you loosen these.
  25. MacBook Pro 16" Late 2023 Screen Replacement, Remove the antenna bar: stap 25, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Remove the antenna bar: stap 25, afbeelding 2 van 2
    • Insert the tip of a spudger between the antenna bar and the frame.
    • Pry up with the spudger to separate the antenna bar from the frame.
  26. MacBook Pro 16" Late 2023 Screen Replacement: stap 26, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement: stap 26, afbeelding 2 van 2
    • Pull the antenna bar straight up and out of the frame to remove it.
  27. MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the screen cable covers: stap 27, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the screen cable covers: stap 27, afbeelding 2 van 2
    • Use a 3IP Torx Plus driver to remove the four 3.5 mm screws securing the screen cable covers.
  28. MacBook Pro 16" Late 2023 Screen Replacement, Remove the screen cable covers: stap 28, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Remove the screen cable covers: stap 28, afbeelding 2 van 2
    • Use tweezers, or your fingers, to remove the two screen cable covers from the logic board.
  29. MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the screen cables: stap 29, afbeelding 1 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the screen cables: stap 29, afbeelding 2 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the screen cables: stap 29, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up and disconnect the right-most screen cable press connectors secured to the logic board.
  30. MacBook Pro 16" Late 2023 Screen Replacement: stap 30, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement: stap 30, afbeelding 2 van 2
    • Repeat the previous step for the left-most press connector.
  31. MacBook Pro 16" Late 2023 Screen Replacement, Remove the screen cable brackets: stap 31, afbeelding 1 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Remove the screen cable brackets: stap 31, afbeelding 2 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Remove the screen cable brackets: stap 31, afbeelding 3 van 3
    • Pull up on the back of the screen cable bracket to release the clips securing it to the frame.
    • Remove the screen cable bracket.
    • Repeat for the other screen cable bracket.
  32. MacBook Pro 16" Late 2023 Screen Replacement: stap 32, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement: stap 32, afbeelding 2 van 2
    • If the two screen cable bracket buffers are removed alongside the brackets, then skip this step.
    • Pull the two screen cable bracket buffers straight up and out of the frame to remove them.
  33. MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the lid angle sensor cover: stap 33, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the lid angle sensor cover: stap 33, afbeelding 2 van 2
    • Use a 3IP Torx Plus driver to remove the two 2.1 mm screws securing the lid angle sensor cover near the right hinge.
  34. MacBook Pro 16" Late 2023 Screen Replacement, Remove the lid angle sensor cover: stap 34, afbeelding 1 van 1
    • Use tweezers, or your fingers, to remove the lid angle sensor cover.
  35. MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the lid angle sensor cable: stap 35, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Disconnect the lid angle sensor cable: stap 35, afbeelding 2 van 2
    • Use the flat of a spudger to pry up and disconnect the lid angle sensor's press connector.
  36. MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the hinge covers: stap 36, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Unfasten the hinge covers: stap 36, afbeelding 2 van 2
    • Use a 5IP Torx Plus driver to remove the four 2.5 mm screws securing the hinge covers (two screws on each side).
  37. MacBook Pro 16" Late 2023 Screen Replacement, Remove the hinge covers: stap 37, afbeelding 1 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Remove the hinge covers: stap 37, afbeelding 2 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Remove the hinge covers: stap 37, afbeelding 3 van 3
    • Use tweezers to pull the hinge covers horizontally away from the hinge to separate them from the frame.
    • Remove the hinge covers.
  38. MacBook Pro 16" Late 2023 Screen Replacement, Remove some of the hinge screws: stap 38, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Remove some of the hinge screws: stap 38, afbeelding 2 van 2
    • Use a 8IP Torx Plus driver to remove two 6.4 mm screws from each hinge (four screws total).
    • Each hinge has a third screw, which you should leave in place for now.
  39. MacBook Pro 16" Late 2023 Screen Replacement, Protect the MacBook: stap 39, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement, Protect the MacBook: stap 39, afbeelding 2 van 2
    • If you plan to re-use your screen, open it and apply a piece of tape to the glass directly above each hinge. This helps protect the glass from getting scratched in the following three steps.
    • Fully open the screen and stand your MacBook Pro up on one side.
  40. MacBook Pro 16" Late 2023 Screen Replacement, Remove the remaining screws: stap 40, afbeelding 1 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Remove the remaining screws: stap 40, afbeelding 2 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Remove the remaining screws: stap 40, afbeelding 3 van 3
    • Use n 8IP Torx Plus driver to remove the two remaining 6.4 mm screws (one from each hinge).
    • Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
  41. MacBook Pro 16" Late 2023 Screen Replacement, Remove the screen: stap 41, afbeelding 1 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Remove the screen: stap 41, afbeelding 2 van 3 MacBook Pro 16" Late 2023 Screen Replacement, Remove the screen: stap 41, afbeelding 3 van 3
    • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
    • Push both halves of the MacBook Pro together so that the hinges can be lifted clear of their recesses in the chassis.
    • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
  42. MacBook Pro 16" Late 2023 Screen Replacement: stap 42, afbeelding 1 van 1
    • Remove the screen.
  43. MacBook Pro 16" Late 2023 Screen Replacement: stap 43, afbeelding 1 van 2 MacBook Pro 16" Late 2023 Screen Replacement: stap 43, afbeelding 2 van 2
    • If desired, add a little blue threadlocker to the screw threads to prevent them from loosening over time.
    • During reassembly, first install the hinge screws without tightening them fully. Then adjust the screen until it is correctly centered and aligned on each side. Finally, tighten the screws.
    • If your screen clicks or snaps upon opening, loosen the hinge screws and adjust the alignment. Make sure the screen doesn't sit too far forward, or it can catch on the body when opening and closing.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" Late 2023 Answers community for help.
5 andere personen hebben deze handleiding voltooid.
Alex Diaz-Kokaisl
217.719 Reputatie
1.087 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.971 handleidingen geschreven
1Gids Commentaar
can we use the same display part for 2024 m4 pro mac ?
Adithya Vinayak Ayyadurai - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 89
Afgelopen 30 dagen: 330
Altijd: 6,106
