Inleiding
Use this guide to replace your bare logic board.
Wat je nodig hebt
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Gereedschap gebruikt in deze stap:P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery$5.49
Remove the two 5-Point Pentalobe screws along the top edge of the battery.
Use your fingernail to flip up the locking flap on the ZIF socket for the keyboard ribbon cable. The locking flap is located at the opposite side of the socket compared to the keyboard ribbon cable. Hook your fingernail under it and carefully lift it up vertically.
Use the tip of a spudger to slide the keyboard ribbon cable out of its socket.
Use the flat end of a spudger to pry the microphone cable connector up off its socket on the logic board.
Disconnect the DC-In Board connector from the logic board by pulling it straight away from its socket.
39 andere personen hebben deze handleiding voltooid.
