Inleiding
Use this guide to replace your heat sink.
Wat je nodig hebt
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Gereedschap gebruikt in deze stap:P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery$5.49
Remove the two 5-Point Pentalobe screws along the top edge of the battery.
Use your fingernail to flip up the locking flap on the ZIF socket for the keyboard ribbon cable. The locking flap is located at the opposite side of the socket compared to the keyboard ribbon cable. Hook your fingernail under it and carefully lift it up vertically.
Use the tip of a spudger to slide the keyboard ribbon cable out of its socket.
Lay the logic board down on a soft flat surface with the heat sink facing up.
Remove the eight Phillips screws securing the heat sink to the logic board.
Carefully lift the heat sink off the logic board.
If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
25 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
I did use a common flathead screwdriver for 5-point and 6-point screws. It' worked well.
Thank you very much for this guide !
I just used this guide to pull out my logic board and clean about 6 years of dust out. Also was able to take apart the fans and throw a little bit of wd40 on the axels. We are back to whisper quiet computing and about 10-15 degrees cooler.
I messed up something because the machine doesn't turn on (
