Inleiding
使用本指南更换裸机逻辑板。 这需要取下附加到逻辑板的每个组件。
Wat je nodig hebt
将电池从主板上倾斜到足以触碰电池电路。
将电池电路从主板上的插座中拔出,然后从上盖取出电池。
把电池充满,然后至少继续充电两个小时。之后,像往常一样使用它,消耗电量。当你看到低电量警告时,保存好你的工作,然后让笔记本开着,直到它因为低电量而入睡。再等待至少五个小时,之后再把你的笔记本充满到100%
如果在安装新电池后你发现了一些异常状况或麻烦,你可能需要重置你的Macbook的设备管理器
要重新组装您的设备,请按照该指南并按照相反的顺序重新组装。
114 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
笑得像个300斤的孩子 helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
24 opmerkingen
Hallo ifix,
I have a Macbook pro 15´ unibody mid 2010, i7, 2,66 Ghz,
but i cant find the exact same logic board, i found a Macbook pro 15´ unibody mid 2010, i5, 2,66 Ghz, can i use that one, or is there a difference between the i7 and i5 logic board? Thanks in advance.
Did you ever get a response regarding this?
As long as the logic board is from a 15” mid 2010 it will fit
Robbe -
I have a 2010 white macbook that I haven't been using in about 6 months. Can I use the logic board in that macbook and install it in a 2012 macbook pro?
