Ga door naar hoofdinhoud
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement
Wat je nodig hebt
  1. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 2, afbeelding 1 van 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement, Battery: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery
    $5.49
    Koop
    • Three Pentalobe screws secure the battery to the upper case. They can be removed with this special driver.
    • If you don't have a Pentalobe driver, a 1.5 mm flathead screwdriver can be used in a pinch. Be sure the head of your flathead screwdriver fits snugly across two of the five "points" of the screw head before trying to break the screw free, as a loose fit will easily strip the screw head.
    • If the head of your screwdriver fits too loosely, find a bigger bit and file it down until it fits snugly before proceeding.
    • You do not necessarily have to follow steps 3-7 to remove the battery in order to replace the hard drive. However, it is recommended to remove all power sources from electronics before working on them.
    It really depends on how thick the 1.5 mm flathead screwdriver is. I tried a low-cost tool and almost destroyed the screw. So be carefull
    Paul - Antwoord
    Unfortunately, when I added a second hard drive via these instructions, all went well but Bluetooth is now MIA. Can anyone help?
    Peter Payne - Antwoord
    I agree...
    I have bought a used MacBook Pro, when problems arise, opening Corps was trying to turn the screw, but with poor quality could not turn a screwdriver, only to ruin the screw. Try to buy ifixit Screwdriver set. Good luck to all and thank you ifixit team for such assistance as ifixit.com. Thank you.
    remjok - Antwoord
  4. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 4, afbeelding 1 van 1
    • Remove the two exposed five-point Pentalobe screws along the top edge of the battery.
    The screws holding my battery were all worn out since an earlier removal. So instead of ruining them even more I put some saran wrap on the tip of my pentalobe driver and gently unscrewed them.
    magnus - Antwoord
    I have a problem with these screw. They a completly warn and I need some new ones to fix the new Battery.
    Does anyone know which thread it is and which length?
    alexanderleith - Antwoord
  5. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 5, afbeelding 1 van 1
    • Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove the five-point Pentalobe screw hidden underneath.
  6. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 6, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 6, afbeelding 2 van 2
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
  7. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 7, afbeelding 1 van 1
    • Tilt the battery back enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
    • If you're installing a new battery, you should calibrate it as soon as possible.
  8. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement, Display Assembly: stap 8, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement, Display Assembly: stap 8, afbeelding 2 van 2
    • Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
    • Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
    • Pull the camera cable away from its socket on the logic board.
    • Pull the connector parallel to the face of the logic board, not straight up.
  9. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 9, afbeelding 1 van 1
    • Peel the camera cable off the adhesive securing it to the optical drive.
  10. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 10, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 10, afbeelding 2 van 2
    • This step is only required if you have an anti-glare display. If you have a glossy display, skip to step 12.
    • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
    • Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
  11. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 11, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 11, afbeelding 2 van 2
    • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
    • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Lift the Bluetooth board/cable retainer assembly out of the upper case.
    Stripped one of the screws cause thread lock was used.
    BillyRachel1 - Antwoord
  12. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 12, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 12, afbeelding 2 van 2
    • This step is only for glossy display machines. If you have an anti-glare display, skip this step.
    • Remove the two 8 mm Phillips screws securing the camera cable retainer to the upper case.
    • One of the screws may remain captive in the camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Lift the camera cable retainer out of the upper case.
  13. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 13, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 13, afbeelding 2 van 2
    • Remove the single 7 mm Phillips screw securing the display data cable retainer to the upper case.
    • This screw may remain captive in the display data cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Remove the display data cable retainer from the upper case.
  14. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 14, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 14, afbeelding 2 van 2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket.
    • Make sure to pull the connector parallel to the face of the logic board, not straight up from its socket.
  15. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 15, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 15, afbeelding 2 van 2
    • Remove the outer two T6 Torx screws securing both display hinges to the upper case (four screws total).
    I've found that T7 Torx bit works better than T6.
    Rob - Antwoord
  16. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 16, afbeelding 1 van 1
    • Open your MacBook so the display is perpendicular to the upper case.
    • Place your opened MacBook on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the remaining 6.5 mm Torx screw from the lower display bracket.
  17. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 17, afbeelding 1 van 1
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining 6 mm T6 Torx screw securing the display to the upper case.
    T7 Torx bit works better than T6. The T6 strips the screw.
    Rob - Antwoord
  18. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 18, afbeelding 1 van 3 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 18, afbeelding 2 van 3 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 18, afbeelding 3 van 3
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
  19. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement, Front Display Glass: stap 19, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement, Front Display Glass: stap 19, afbeelding 2 van 2
    • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
    • Before starting, be sure to clean the display glass with lint-free cloth moistened with a mild solution; it will make the suction cup adhere better, and will make checking for dust on reassembly easier
    • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
    • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
    • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
    Another caution is needed - the heat gun is capable of discoloring the LCD panel (giving uneven coloration) if it overheats. This is possible on the low setting. Proceed cautiously, heating in increments until the glass releases.
    Alden Stradling - Antwoord
    I was wondering the same, is absolutely necessary to disassemble the screen to change the glass? Can I jump to step 21?
    caholzmann - Antwoord
    To change just the glass I used a hair dryer it gives off enough heat to do the job. Stand the computer up on its cover with the key board standing up.start at a corner heat the adhesive as you go along. I Put credit cards in as I went along so the adhesive doesn't stick again. take your time . Its easy.
    Robert Lachman - Antwoord
  20. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 20, afbeelding 1 van 3 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 20, afbeelding 2 van 3 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 20, afbeelding 3 van 3
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Koop
    • With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
    • Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • Slowly and gently pull the corner of the display glass up off the display assembly.
    • If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
    Sufficiently heated is a meaningless phrase here. Is it two minutes? Three? Fifteen? An hour? I have tried doing this for increasing amounts of time while avoiding doing damage to the machine, and nothing is working. Sufficient heating needs definition.
    Keith McComb - Antwoord
    Hi Keith, the key here is that you want to warm the adhesive that's spread thoroughly behind the masked-black area of the glass around the screen to release, but not put enough heat at the rubber gasket that seals the closed top lid to the base. Too much heat, too soon, will deform the rubber. Too much and you'll never get the glass to release. The 2x that I have done this, however, even with sufficient (and significant) heat, I remember the glass taking a surprising amount of leverage to pull clear. A tactic: using your heat gun warm all the sides of the display from the front, in a circulating/racetrack fashion - about 20 rpm. After 30sec, focus on the left and top sides, seesawing from bottom left, to top left, to top right, and back. Do that at the same pace, about 5-10 passes. Then spend about 10 sec waving over the whole top left corner. That should get enough heat to enough places to help the glass separate to start placing picks, and you can continue to heat the margins as you progress.
    johnkimmel - Antwoord
  21. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 21, afbeelding 1 van 3 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 21, afbeelding 2 van 3 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 21, afbeelding 3 van 3
    • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
    • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
    • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
    Be careful with the spudger and the soft rubber strip around the glass. Since the rubber strip has been heated up by the heat gun, it is easily smushed and deformed by the spudger.
    Rob - Antwoord
    Be patient and work slowly or else you will crack the glass like me.
    I can not get the glass to come up despite two tries and dicsoloring the LCD with too much heat. Why can't I get the glass to budge at all?
    bollucks66 - Antwoord
    It is better , instead of using the suction cup , to use small flat end spudger . The suction cup should be used first to detach the window from the gasket , not furthermore as it may brake the glass.
    Thierry de Montblanc - Antwoord
    I didn’t have large suction cups and the small ones didn’t work for me. Instead, I used an opening tool to pry up the glass slightly and got a guitar pick under it. Then I slowly worked the pick around the top three sides of the glass, heating sections of glue as I went.
    Daniel Arnfield - Antwoord
    I’ve managed to do it using hair dryer on max. First corner was though and took a lot of time to lift it. I decided to heat not only a corner but whole length and then it came off. I’ve put so much heat that was afraid I’ve damaged LCD, but it works fine. As BillyRachel1 said: patience is the way. In order to assemble it back I used old glue heated again. It’s easy but takes time.
    Note: Don’t do this at home if you have cats otherwise you going to spend next hour or so trying to remove their fur from between glass and LCD. It’s because they all levitate after using hot air and just wait to stick to the screen again.
    To be honest hardest thing was replacing clutch cover, took me so much time and I eventually cracked it.
    D. K. Labudek - Antwoord
  22. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 22, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 22, afbeelding 2 van 2
    • Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
    • Attach a suction cup along the right side of the front glass panel.
    • Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
    • Continue working along the right edge of the front display glass until it is separated from the display.
    • It may be helpful to use a guitar pick or another thin plastic object to keep the upper right corner of the front glass panel from sticking back down to the display assembly.
    If you don't have a guitar pick, playing cards works too.
    Rob - Antwoord
    I used old credit cards
  23. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 23, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 23, afbeelding 2 van 2
    • Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
    • Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
    • Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
  24. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 24, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 24, afbeelding 2 van 2
    • Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
    • Attach a suction cup near the upper left corner of the glass display panel.
    • Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
    • Once the upper left corner has been separated from the display, it may be helpful to use a guitar pick or another thin plastic object to keep the glass from sticking back down to the display assembly.
  25. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 25, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 25, afbeelding 2 van 2
    • Use a heat gun to soften the adhesive under the black strip along the left side of the front glass panel.
    • Attach a suction cup along the left side of the front glass panel.
    • Continue working along the left edge of the front display glass until it is separated from the display.
  26. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 26, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 26, afbeelding 2 van 2
    • Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
    • If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
    • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on.
    If you will be reusing the glass, with new adhesive, then you will want to remove the old adhesive. This is a bit of a pain, as alcohol doesn't work, and you need to be careful to avoid damaging the black screen border, which is black paint on the back (adhesive) side of the glass.
    To remove the adhesive, note that it is actually a thin film with rubber cement on both sides. First, use a razor to carefully pull up one corner of the film and gently peel it off of the glass. If you are gentle and slow, the underlying adhesive may also come off; if not, then rubbing with your finger or a hard rubber eraser will do the trick.
    griscom - Antwoord
    what to do when new glass starts to peel after a week ?
    labig - Antwoord
    If this is a rubber cement based glue, then would rubber solvent / thinner like N-Heptane help the removal process without damaging the black paint ?
    Sandman619 - Antwoord
    Don’t remove glue. Just reuse it by heating and sticking it again.
  27. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 27, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 27, afbeelding 2 van 2
    • Insert the edge of a plastic opening tool between the display glass and the camera bracket, and run it around the camera bracket to separate it from the display glass.
    • Do not forget to stick the camera bracket down to the new front display glass before reassembly.
    This step is only needed if replacing the glass. If you are only replacing the LCD, there is no need to do this step
    Rob - Antwoord
  28. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 28, afbeelding 1 van 3 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 28, afbeelding 2 van 3 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 28, afbeelding 3 van 3
    • During the glass removal process, the camera cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your camera cable is still connected to the camera board, skip this step.
    • To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the camera cable ZIF socket.
    • Use the tip of a spudger to flip up the ZIF cable retainer on the camera cable socket.
    • Insert the camera cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
    • Reapply the piece of tape covering the camera cable socket.
  29. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement, LCD: stap 29, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement, LCD: stap 29, afbeelding 2 van 2
    • Slide the clutch cover toward the right edge of the display.
    • The clutch cover will move approximately .25" and stop. Do not force it too far to the right.
    • When reinstalling the clutch cover, be sure to slip it over the components protruding from the lower edge of the display about .25" to the right of its final installed position on the display.
    Do you necessarily need to remove the glass before you can remove the clutch cover?
    aye oh - Antwoord
  30. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 30, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 30, afbeelding 2 van 2
    • Starting at its far left end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
    • Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
    • Lift the clutch cover up off the front bezel and set it aside.
    • When reinstalling the clutch cover, be sure to widen the opening when slipping it over the small black plastic cosmetic cover that fills the open end of the clutch cover when it is in place. The cosmetic cover has very thin and delicate plastic arms that hold it to the right clutch hinge.
  31. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 31, afbeelding 1 van 1
    • Remove the six 2.9 mm Phillips screws securing the LCD panel to the front bezel.
    Hey guys, I need to get the part where the screws are on, whats its name or where could I find it? That part on my Computer broke.... Do you guys think its possible to guet it somewhere?
    diegoantegr31 - Antwoord
  32. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 32, afbeelding 1 van 1
    • Pull the LCD toward the top edge of the display to slide the circuitry along its lower edge out of the recess in the aluminum display assembly.
    • It may be helpful to use one hand to feed the display data cable through its channel in the aluminum display assembly as you pull the LCD toward the top edge of the display with the other hand.
  33. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 33, afbeelding 1 van 1
    • Peel the piece of tape covering the display data cable connector away from the edge closest to the LCD.
  34. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 34, afbeelding 1 van 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 LCD Replacement: stap 34, afbeelding 2 van 2
    • Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
    • Pull the display data cable straight away from its socket on the LCD.
    • Lift the LCD out of the display assembly and set it aside.
    • If you are replacing the LVDS/display data cable, simply de-route it from its slot cut into the display casing.
    Danke für das Bereitstellen der Anleitung dadurch konnte ich mein MacBook nach 12 Jahren Einsatz, für die nächsten Jahre fit machen.
    Thanks you for providing this Manuel. It helped me, after 12 year of use to make my MacBook fit for the coming years.
    Albert Zweistein - Antwoord
Conclusie
35 andere personen hebben deze handleiding voltooid.
2 opmerkingen
I followed steps exept heatgun and I did it my expirience from1-10 is 2. Thanks
uho00 - Antwoord
4/4/2020 - I replaced the battery to my mid-2009 MacbookPro earlier, and so was comfortable with the early steps. Removing the battery and all the screws went well. Detaching cables was easy, but reattaching them was tough. Specifically, step 32 in reverse was the most difficult part. I recommend applying a new piece of electrical tape once you reattach the cable to keep them together. Otherwise trying to reassemble the lcd was impossible for me. I also had to extract the cable and re-thread it, attached to the lcd, clip side through the metal case. Once it was through there, I spent a few minutes delicately cleaning the lcd and the top screen. Ensuring everything was clean was also challenging. Re-assembly afterwards went well. Right away I turned on my computer and my screen was perfect. Coupled with the new battery and a round of Clean my Mac, and everything works perfectly. All the steps are correct, and this took a couple hours to complete.
Aaron Friedman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 35
Altijd: 39,683
