Inleiding
No power to the laptop? Replace the DC-In Board.
Wat je nodig hebt
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Three Pentalobe screws secure the battery to the upper case. They can be removed with this special driver.
Use the flat end of a spudger to pry the fan cable connector up off its socket on the logic board.
Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
Disconnect the DC-In Board connector from the logic board by pulling it straight away from its socket.
32 andere personen hebben deze handleiding voltooid.
