Inleiding
Use this guide to replace a broken MagSafe DC-In board.
Wat je nodig hebt
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
Pull the MagSafe DC-In board cable toward the heat sink to disconnect it from the logic board.
Remove the MagSafe DC-In board.
130 andere personen hebben deze handleiding voltooid.
12Gids Commentaar
Piece of cake, took an hour or so, but I was being extra careful. The only sticky part were the backlight cable and the keyboard ribbon cable ZIF socket, those two items I found fiddly to get re-inserted properly. Thanks for the tutorial.
Thankyouuuu your guide very helpfull
Here's some tips to avoid left any screw : use a transparant tape with the sticky note and write or give the code…
I ussually give 3 layer of tape and devide into several sticky note… :)
Excellent guide! My seven-year-old Macbook now charges again without me having to tighten the power cable at weird angles!
The hardest part of this repair was getting the microphone out. That thing was glued in tightly, the rubber shroud is hard to grip through, and the little wires are so delicate!
Worked like a charm! Take your time. Directions were great but some of the connections were a little fiddly. Pay close attention of exactly how the connectors come apart. For these 67 year old eyes, a magnifying glass would have been handy along with some tweezers to replace fat fingers for getting some of the connections started.
