Ga door naar hoofdinhoud
MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement
Wat je nodig hebt
  1. MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement, Remove the lower case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.8 mm screws
    • Two 5.3 mm screws
    • Two 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 2, afbeelding 1 van 2 MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 2, afbeelding 2 van 2
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight separation between the lower case and the chassis.
  3. MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 3, afbeelding 1 van 3 MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 3, afbeelding 2 van 3 MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 3, afbeelding 3 van 3
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  4. MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 4, afbeelding 1 van 3 MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 4, afbeelding 2 van 3 MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 4, afbeelding 3 van 3
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  5. MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 5, afbeelding 1 van 3 MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 5, afbeelding 2 van 3 MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 5, afbeelding 3 van 3
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  6. MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 6, afbeelding 1 van 3 MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 6, afbeelding 2 van 3 MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 6, afbeelding 3 van 3
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • It may help to pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
    • The edges of the case can be sharp, so grip the sides carefully.
  7. MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: stap 7, afbeelding 1 van 1
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Carsten Frauenheim
117.890 Reputatie
339 handleidingen geschreven
iFixit Lid van iFixit
Staff
141 Leden
17.895 handleidingen geschreven
Één opmerking
Fantastic guide! Makes no sense why Apple makes such a simple thing so hard. Almost thought I broke something.
Eli Dinh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 128
Afgelopen 30 dagen: 686
Altijd: 22,663
