Inleiding
Use this guide to replace the MagSafe DC-In board.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Remove the plastic cover adhered to the battery contact board.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
when doing this with metal tweezers as instructed in the video, it was difficult to get off and apparently while i was trying to do it, the tweezers went too far under and i believe made contact with the screw underneath? there was a zzz noise, an orange flicker and a little stream of smoke that came out. i freaked out and put everything back together to see if the laptop even still worked, it turned on and everything but died right away (i drained it before doing the repair anyway, so i was surprised it turned on at all).
i finished the battery repair and did several other things while in there. i have charged it all the way as recommended and will use it later on to see how everything is, im hoping that it’s a okay, but could someone explain to me what happened and the possible consequences?
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
you must lift it absolutely vertically, or it fouls against the locator pin in the corner- you can easily get the impression that it won’t come over the end of this pin- almost like it’s rivetted in. it isn’t. get a good grip on it with the tweezers in the centre hole & one of the sides, & lift it STRAIGHT up.
I would recommend to use plastic tweezers in order to reduce risk of damage.
Second that. If you have thin heat shrink tubing, form some over the tweezer tips. If the tubing is thin and small enough in diameter you’ll see the serrations of the tweezer tips.
wat is the model this SSD
Remove the following screws securing the heat sink to the logic board assembly:
One 2.4 mm Phillips #00 screw
One 3.4 mm T5 Torx screw
Four 2.7 mm T5 Torx screws
Hi,
found 4 rubber spacers on the 4 2,5mm screws
Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
Pull the right fan ribbon cable straight out of its socket on the logic board.
Hey! You skipped a step!
What about the cable (don't know what it does) that runs right across the fan, interfering with pulling the fan out.
It's still in place in Step 14, but here in Step 15 it's magically removed itself, and can be seen resting luxuriously on top of the Airport card.
How do we get that outta there?
Like @victorgav mention, Just need a step before this one, which is to remove the cable that goes across the top of the fan.
Thanks for bringing this up! It looks like the guide was missing the iSight cable disconnection steps. I’ve added the missing steps.
Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
Use the tip of a spudger to push the edges of the I/O board connector straight out of its socket on the logic board.
Repeat the previous procedure to disconnect the Trackpad ribbon cable from its socket on the logic board.
I discovered that if the trackpad cable is damaged the keyboard will not work. I replaced the trackpad cable which had two damaged Ribbon pens. Once TP cable was replaced the keyboard also worked!
Carefully grasp the corner of the logic board (opposite of the I/O ports) and lift the logic board out of the upper case.
When re-installing the Logic board, be careful not to trap any of ZIF cables under the board.
You’ll need to tilt the board up from the end away from the DC-IN board in order to get the IO connectors inserted all the way. Be careful with the little fingers on top of the IO connectors.
I had previously replaced the battery with the Newer Tech battery. The battery cable is not as flexible as the original battery, making the removal and insertion of the trackpad cable difficult.
Gently push the edges of the MagSafe cable connector away from its socket on the logic board.
9 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Thanks a lot for this guide ! I completed it with no problems… I never did this kind of unmount/repair and thanks to the iFixit Essential Electronics Toolkit, ++Arctic Silver Thermal Paste++ and Arctic Silver ArctiClean it was a breeze to complete. I think I have put too much thermal paste but it is no problem. The macbook now works like a charm.
Missing instructions on how to remove iSight camera cord during removal of right fan.
You can find it under step 15 of the logic board removal.
Otherwise so far it’s a great tutorial.
If don’t have one of those neat project mats, then you can use small pieces of flattened blu-tack to hold the screws. If you arrange them in the shape of your mac book cover, and put the screws down methodically, you can get a one-to-one mapping of the screws to the correct screw holes.
Toby Thurston - Antwoord
Or you can use an ice tray where you put the screws and the parts in separate bays in the same order as they come in the instructions.
timofej.se -
This is great! I used a small magnetic white board, and wrote on it to identify the parts as I went. This whole process, from the fast shipment to the great instructions to the complete, high quality, tool kit has been great. I’m typing this comment on my resurrected laptop. Thank you! Sue
Susan Greer - Antwoord
It would be a good idea if people recorded in the comments which screws go where so that, if someone lost their screw positions, they could recover them from the comments.
Raymond Shpeley - Antwoord
