Inleiding
Replace or upgrade your MacBook Core Duo's hard drive with a new SATA hard drive or SSD up to 9.5mm thick. A new drive can give you extra storage space and also increase your MacBook's speed.
Wat je nodig hebt
Video overzicht
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Grasp the white plastic tab attached to the hard drive and pull it to the right, removing the hard drive from the computer.
Remove the two black T8 Torx screws securing the silver bracket to the hard drive.
612 andere personen hebben deze handleiding voltooid.
20 opmerkingen
Thanks iFixit for this great walkthrough. Yes, it worked find. Have a look: http://www.vimeo.com/17134347 ;) Keep on rockin' /Sebastian
Any suggestions for when the rubber track comes out with the hard disk? Short of dismantling the whole thing?
I saw no replies to the "black rubber lip in the slot" comment. What is the fix for that rubber liner track strip coming loose from the inside of the HD enclosure, please?
Mike -
Thanks for the guide, iFixit! It worked like a cham.
I was wondering if there are any harddrives that are known to be incompatible with this MacBook (aside from dimensions of course)?
