Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
The processor clamp helps keep the heat sink close to the processors.
  1. Unplug your MacBook Air and power it off before you proceed.
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs. Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. Disconnect the battery connector by pulling it straight out of its socket.
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. Remove the following nine screws securing the battery to the Air:
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. Lift the battery out of the Air.
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. Remove the 1.9 mm Phillips screw securing the processor clamp to the heat sink.
    • Remove the 1.9 mm Phillips screw securing the processor clamp to the heat sink.
  7. Lift the processor clamp off the heat sink.
    • Lift the processor clamp off the heat sink.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 11,521
