Ga door naar hoofdinhoud
MacBook Air Models A1237 and A1304 Logic Board Replacement
Wat je nodig hebt
  1. MacBook Air Models A1237 and A1304 Logic Board Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 2, afbeelding 1 van 2 MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 2, afbeelding 2 van 2
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Air Models A1237 and A1304 Logic Board Replacement, Battery: stap 3, afbeelding 1 van 1
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 4, afbeelding 1 van 1
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air Models A1237 and A1304 Logic Board Replacement, Hard Drive: stap 6, afbeelding 1 van 3 MacBook Air Models A1237 and A1304 Logic Board Replacement, Hard Drive: stap 6, afbeelding 2 van 3 MacBook Air Models A1237 and A1304 Logic Board Replacement, Hard Drive: stap 6, afbeelding 3 van 3
    • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
    • Pull the audio out ribbon cable off the adhesive securing it to the upper case.
    • Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
  7. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the audio out cable from its socket on the port hatch ribbon cable.
  8. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 8, afbeelding 1 van 1
    • Use a spudger to pry the hard drive cable connector up off the logic board.
  9. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 9, afbeelding 1 van 2 MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 9, afbeelding 2 van 2
    • Use the sharp end of a spudger to de-route the microphone cable from the hard drive bracket.
    • Remove the cosmetic screw cover from the adhesive securing it to the hard drive bracket.
  10. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 10, afbeelding 1 van 1
    • Remove the four Phillips screws securing the hard drive assembly to the upper case:
    • Two 4.7 mm screws.
    • Two 3.9 mm screws.
  11. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 11, afbeelding 1 van 1
    • Lift the hard drive assembly out of the upper case.
  12. MacBook Air Models A1237 and A1304 Logic Board Replacement, Heat Sink: stap 12, afbeelding 1 van 1
    • Use the tip of a spudger to pull the fan cable connector straight away from its connector on the logic board.
  13. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 13, afbeelding 1 van 2 MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 13, afbeelding 2 van 2
    • Use the tip of a spudger to move the cosmetic fan cover aside.
  14. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 14, afbeelding 1 van 2 MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 14, afbeelding 2 van 2
    • If you have the original version of the MacBook Air (A1237), refer to picture 1. Remove the following screws securing the heat sink to the logic board:
    • One 5.9 mm Phillips screw.
    • Two 1.9 mm Phillips screws.
    • One 1.9 mm Phillips screw.
    • If you have the A1304 version of MacBook Air, refer to picture 2. Remove the following screws securing the heat sink to the logic board:
    • One 5.0 mm Phillips screw
    • Five 1.9 mm Philips screws.
    • One 2.5 mm Phillips screw.
  15. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 15, afbeelding 1 van 1
    • Lift the processor clamp off the heat sink.
  16. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 16, afbeelding 1 van 1
    • Deroute the microphone cable away from the channel in the fan.
  17. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 17, afbeelding 1 van 1
    • Lift the heat sink up off the logic board.
    • Be mindful of the microphone cable when lifting the heat sink, as it can get tangled on the top edge of the fan.
    • When you mount the heat sink back onto the logic board, be sure to apply a new layer of thermal paste. We have a guide that makes replacing the thermal paste easy.
  18. MacBook Air Models A1237 and A1304 Logic Board Replacement, Logic Board: stap 18, afbeelding 1 van 1
    • Use a spudger to pry the audio cable connector up off the logic board.
  19. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 19, afbeelding 1 van 1
    • If present, remove the small piece of black tape covering the microphone cable connector.
    • Disconnect the microphone cable by pulling its connector straight away from the socket on the logic board.
  20. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 20, afbeelding 1 van 2 MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 20, afbeelding 2 van 2
    • Remove the two small Phillips screws securing the logic board bracket to the upper case.
    • Lift the logic board bracket out of the upper case.
  21. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 21, afbeelding 1 van 2 MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 21, afbeelding 2 van 2
    • Use a spudger to pry the AirPort/Bluetooth and trackpad control cable connectors up off the logic board.
  22. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 22, afbeelding 1 van 1
    • Disconnect the DC-In cable by pulling its connector straight away from the socket on the logic board.
  23. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 23, afbeelding 1 van 2 MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 23, afbeelding 2 van 2
    • Remove the small Phillips screw securing the display data cable ground loop to the upper case.
    • Disconnect the display data cable by pulling its connector straight away from the socket on the logic board.
  24. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 24, afbeelding 1 van 1
    • Remove the three Phillips screws securing the logic board to the upper case.
  25. MacBook Air Models A1237 and A1304 Logic Board Replacement: stap 25, afbeelding 1 van 1
    • Lift the logic board out of the upper case.
Conclusie
57 andere personen hebben deze handleiding voltooid.
5Gids Commentaar
nice its very helpful for each other.
Rjames Tabuzo - Antwoord
I currently have a 1.6ghz A1237 Original Macbook Air, and I was wondering if the logicboard is interchangeable with the late 2008 model A1304. I hope someone can answer this for me. I want to swap out the logic board for A1304.
ric2081263 - Antwoord
I have the same question too. Who can help me because I want to upgrade to El Capitan instead of Lion
Tom Xu -
great work and helpful!
frank.haubold - Antwoord
Can we upgrade or add, make part from new mac dumbed down? advisor meeting with your board
Donald Eugene Moore - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 153
Altijd: 136,429
