Ga door naar hoofdinhoud
MacBook Air 13" Mid 2012 Solid-State Drive Replacement
Wat je nodig hebt
  1. MacBook Air 13" Mid 2012 Solid-State Drive Replacement, Lower Case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Koop
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
    Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
    allison - Antwoord
    Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
    bwgvanderveer - Antwoord
    I thought I could replace my 256 Gb SSD with 512? regards
    ola m - Antwoord
    Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
    andrew - Antwoord
    It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
    Larry Smith - Antwoord
    tell a model that was not inferior to the speed of the one in the laptop.
    Thank you
    ilyabuhov - Antwoord
    Do i need to order tools separately to replace the battery i just ordered?
    anne uhlir - Antwoord
    im looking for a Logic Board for a
    Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
    Any help is appreciated.
    Jamie Comstock - Antwoord
    P5 pentalobe screwdrivers are too big! The correct size for these screws are p4 pentalobe. P5 pentalobe was just able, with difficulty, to turn some of the screws. If the screws were at all tight, my p5 was unable to get them out, and started to strip the screws. A p4 screwdriver fit better and removed the screws with ease. (I was using high quality Wiha brand screwdrivers.)
    William Skinner - Antwoord
    I had same experience (with MacBook Air 13-inch Mid-2012) … had to get P4, which worked swimmingly
    eric -
    Very simple installation. The screwdriver heads were exactly what we’re needed, one head for the outside case screws, the other for the screws holding the battery in place. The computer started right up. Now to see how the battery holds up, but I have a good feeling about this!
    Dennis Eaton - Antwoord
    My P5 and the T5 worked perfectly with my early 2015 Air 13”! And it is super fast! Thank you iFixit!
    Pennny Beach - Antwoord
    The supplied kit and instructions worked perfectly!
    Nikolay Andreev - Antwoord
    Comments that the P5 pentalobe are too large are absolutely spot-on. There is no way the P5 pentalobe bit I have will work with the MacBook Air without destroying the screws. Hard target search for P4 pentalobe bit in progress…..
    joemoog - Antwoord
    Bonjour j’aimerais changer mon SSD de 128 Go pour en mettre un de 512 Go. Je ne sais pas ce qu’il faut prendre car il faut qu’il soit compatible avec le macbook air A1466. J’aurais vu un Samsung Evo 970 500 Go mais si je ne me trompe pas, il faut un adaptateur.
    Merci pour votre aide.
    chicco33 - Antwoord
    oui, vous aurez besoin d’un adaptateur, pour completez le changement.
    Dan -
    The tool kit should include tweezers for re-inserting the battery connector.
    Andre Clement - Antwoord
    P5 pentalobe worked perfectly for me. Instructions were spot-on. Antenna connections were a bit fiddly to refit but got them in ok.
    michaelquinnell - Antwoord
    Maybe the problem some are experiencing is that the designations are confusing (blame Apple rather than iFixit). the P2 is also known as PL1. The P5 is also known as PL4. The P6 is also known as PL5. So it is possible to mistake the P6 (PL5) for the P5 (PL4), meaning it (P6-PL5) will be too big, while the P5 (PL4) will be just right. Sort of a 3 Bears explanation, but it is very confusing.
    Thomas Lewis - Antwoord
    To add to this. In searching for the P5 screwdriver to buy in UK, as far as I can tell, it is also known as
    Pentalobe 1.2(mm)
    also
    P4 = 0.8
    P6 = 1.5
    Just unscrewed the back case of MacBook Air 13” mid 2011, with no problems using Pentalobe 1.2
    nijafe -
    I have not replaced a display on the A1369 but have done many A1466 which is a newer 13” model. They seem really similar and its not clear why one needs to remove the logic board to remove the display. The antenna cables on the A1466 dont have to rest under the logic board but can be tucked in the hinge crevice. Cant this same thing be done with the A1369?
    Sean Love - Antwoord
    Did mine today - but new battery wasnt charging. Went back in and noticed the battery connector cable was not quite 100% “seated. It was sticking out by less than a millimetre! - you need to give it quite a firm push in to get it seated properly. Otherwise - all ok .
    John Brennand - Antwoord
    Just installed on a MacBookAir6,2 (13-inch, Early 2014).
    Was very easy.
    New iFixit battery looks great so far:
    Full Charge Capacity (mAh): 4922 -> 7333
    Jonathan Cross - Antwoord
    can you tell me which size of screwdrivers you’ve used to crack it up, please? I have the same model and size,
    hawk_lpc -
    Screw P5 Pentalobe 1.2
    Mario Verlent - Antwoord
    Install went flawlessly. Only challange was reattaching blue tooth antennas. Those sockets are so tiny.
    Joel Sebastian - Antwoord
    Installation was a little challenging at first because the instructions on this site did not perfectly match my model (late 2013 to early 2015).
    Found this video on YouTube which described the procedure perfectly https://www.youtube.com/watch?v=Lue6lVWh...
    Also the Ifixit kit I received was well put together with everything I needed and more. The calibration went perfectly and I am very pleased. Will buy again!!
    Donald Niamath - Antwoord
    Gently pulled out connector of old battery, then pressed and held the power switch for 1 minute. Unscrewed and removed the old battery. Pressed and held power switch for 1 minute again. I know from previous work that this helps drain charge from spontaneous recharging as the dielectric recovers. Gently “fine tuned” leads from new battery to connector till connector stuck out at right angle to the edge of battery. Held the battery by the edges and let the connector slide into the socket. Set the battery down and put the screws in all the way. Then checked that the connector was completely seated before tightening the screws. The laptop come on immediately and showed 98% charge and registered normal (checked in “About this Mac”. Very happy to this point. Now for calibration.
    Amir Zaidi - Antwoord
    Thank you very much for the guilde. My MBA2011 had reborn !
    Billy Wong - Antwoord
    Allow for electrostatics, otherwise you may cook components on the logicboard /motherboard (like I did with one of these!)
    See great advice: Electrostatic Discharge
    Fletcher Cole - Antwoord
    … und wenn du eines von diesen wirklich kleinen Schräubchen vermisst: bevor du den Boden aufkehrst oder mit einem starken Magneten absuchst, schau mal am seitlichen (magnetischen) Ladekabelanschluss nach … ?
    ... and if you miss one of these really small screws: before you sweep the floor or search it with a strong magnet, take a look at the (magnetic) charging cable connection on the side … ?
    Blatt - Antwoord
    Fot All People ha ing trouble finding their SSD
    DONT PRESS CMD +R + POWER
    instead press
    OPTION+CMD+R +POWER
    I just installed Monterrey with WD black sn 770 SSD in m'y macbook air 2015
    Albert - Antwoord
    IFixit just had me submit "my story" re. fixing my MacBook Air 2013.
    This repair was NOT difficult. The battery is enclosed in a plastic frame. It is NOT glued in like the newer models of Apple laptops. And unlike older laptops, the battery is not totally enclosed in a plastic housing. So once you remove the screws holding the batterie's frame, you can remove the battery.
    Follow the instructions. Read the comments. Also read the comments re. installing a new battery.
    Good luck. - Eric J.
    ECJohansen - Antwoord
    On the back of the laptop, notice that each screw is angled a little bit inward, aiming toward the middle of the laptop. Keep your screwdriver lined up with the screw (angled a bit outward as seen at 01:23 in the video: https://youtu.be/tToAwO6f-SY&t=83). This will help you get a good bite on the screw to get it out and avoid stripping the head of the screw.
    Use the same angle when putting each screw back in. If the screw is in line with its hole it should not feel like you are fighting to screw it in. If it does, check your angle and back up a little; you should feel the screw fall into line.
    Rich Garella - Antwoord
    shrhh - Antwoord
  2. MacBook Air 13" Mid 2012 Solid-State Drive Replacement: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
    Jeannie Crowley - Antwoord
    To add - the slim 1cm tab “nub” is on the centre of the back cover & fits into a hole in the battery frame. I ran my fingers around the whole of the cover to eventually here it click out.
    nijafe -
    When closing this back up make sure that the antenna cable is tucked away neatly
    Gabriel - Antwoord
    So this is a legit back cover for MacBook Air?
    ASHANTI SMITH - Antwoord
    What about disconnecting the battery?
    Luke - Antwoord
    I bought the part and tools from iFixit and followed the directions. The mechanical part went smoothly - maybe 10 minutes to disassemble/replace/reassemble.
    Getting Catalina (the current MacOS) to install was not working until I used Cmd-Opt-R (as noted in the OWC paper sheet that came in the box) which brought up the proper installer - I believe from a pre-prepared bootable SD card but it’s hard to say. From there the install succeeded taking ~1.5 hours.
    Beware that (a) the install requires a working internet connection for verification and updates, and (b) the system must have been running at least macOs 10.13 (High Sierra) before the install in order to have an EFI BIOS that recognizes the SSD.
    Lance Berc - Antwoord
    As noted by others, be a bit careful removing the lower case. There is an oblong black plastic locator very near the center of the lower case. Unless you gently pry the bottom cover pretty much straight up, you will break the ends off of the locater.
    BobY - Antwoord
    Thanks for the detailed photos. When repairing equipment, I don’t really like to disassemble plastic parts, they can be damaged, but your screenshots help a lot. For my studies, I am writing an essay comparing the reliability of laptops from various manufacturers and the complexity of their repair, maybe it will be useful for someone to check the essay for plagiarism here essay checker, when comparing different manufacturers, I understood why people love Apple so much. The minimum number of failures. Of course, repairing it in an official service is not cheap, but with the help of such detailed instructions, you can do it yourself and save a lot.
    Nexus - Antwoord
    The screwdriver bit to use on these case screws is not named, but I found that my "CR-V 1.2" did the job nicely.
    The driver for the screws inside the case are named, as "T5".
    Jim Henderson - Antwoord
  3. MacBook Air 13" Mid 2012 Solid-State Drive Replacement, Battery Connector: stap 3, afbeelding 1 van 2 MacBook Air 13" Mid 2012 Solid-State Drive Replacement, Battery Connector: stap 3, afbeelding 2 van 2
    • As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Be sure to pull the connector horizontally toward the battery, and not straight up from the Air, or you may damage the socket on the logic board.
    The clear plastic tab is missing on mine. Whoever worked on my laptop before me seems to have ripped it off. Now what?
    mjmorawski - Antwoord
    My plastic tab pulled off the connector. I worked the connection apart using two spurgers, slowly backing it out side to side.
    Ric Thistlethwaite - Antwoord
    I don’t see my socket on logic board, how can I fix it
    QUYNH PHAM - Antwoord
  4. MacBook Air 13" Mid 2012 Solid-State Drive Replacement, Solid-State Drive: stap 4, afbeelding 1 van 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
    Should this screw be really difficult to remove?
    Kitty - Antwoord
    It should give a little resistance but not a lot that it doesn’t come out.
    Jonathan - Antwoord
  5. MacBook Air 13" Mid 2012 Solid-State Drive Replacement: stap 5, afbeelding 1 van 2 MacBook Air 13" Mid 2012 Solid-State Drive Replacement: stap 5, afbeelding 2 van 2
    • To avoid damaging its socket, do not lift the end of the SSD excessively.
    • Slightly lift up the end of the SSD and pull it straight out of its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
    I’ve heard tales of an adapter that will make this computer work with a stand SSD drive.
    Doesn’t seem like there’s enough space to make it work, but if this is possible I’d love to learn more.
    Alberto Einsteino - Antwoord
    Yes, you can put a normal SATA SSD in, with an adapter. I just installed a WD Blue 1TB. This page explains all the details: https://macandegg.com/upkeep/macbook-air...
    peternorthup - Antwoord
Conclusie
91 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
502.990 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.139 handleidingen geschreven
17 opmerkingen
I understand this is probably a noob question, but can somebody explain what is preventing anybody from swapping a 128GB SSD for a 256GB?
Eugene General Ed - Antwoord
Eugene - nothing, I just followed this guide to upgrade from 256GB to 512GB. It's just that MBA 2012 SSDs are pretty hard to come by. I had to lurk on eBay for quite some time.
Julian - Antwoord
How do I get the operating system on to SSD?
perarve - Antwoord
You should be able to transfer the os installer into an 8+ gb thumb drive via DiskMakerX. You do need a working mac with something that works with the mac app store installed and enough space to download the os from the app store. Afterwards, just boot up your mac with the alt key, and install.
diskmakerx.com
Are you certain it's a P5 pentalobe driver? We found the P5 doesn't fit, and have always used a Wiha 267IPR / 4IPR x 40
Mac Justice - Antwoord
Many may not know that the SSD for this model (apparently Macbooks from 2011 to 2013) can be upgraded with a commercial off the shelf M.2 form factor SSD and an additional adapter (from proprietary Macbook connector to M.2/NGFF). The M.2 Standard allows different logical device interfaces, but since the Macbook is limited to SATA access, this must be supported by the SSD (in contrast to PCI Express). I successfully upgraded my Macbook using this SSD http://www.amazon.de/Samsung-MZ-N5E500BW... with this adapter http://www.amazon.de/Adapter-Macbook-MD2... . Just wanted to share this with the community, even TRIM support can now be activated since OS X Yosemite for non-Apple SSDs using trimforce in Mac OS terminal.
Hubsi - Antwoord
Thank you. You have the most useful information on this site.
love.james.r -
Great info,
I have a Macbook Air 11 inches - Mid 2012. I read somewhere that only 128GB and 256GB SSD can be installed with an adapter. I’d like to install the 512GB model. Can you please confirm that it can be done?
Thanks
Fabio Pulito -
someone knows if this SSD is compatible with the macbook pro retina 15” 2012/ early 2013? Thank you.
fporcelli2010 - Antwoord
MD760LL/A ModelA1466 (EMC 2632) with SanDisk SSD (SDNEP 655-1838C)… The Mother Board failed and I would like to recover the data off of the drive prior to selling it out for parts. Does anyone know of an adaptor that works for this model of SSD?
Any help would be greatly appreciated!
Glen Becker - Antwoord
You can find adapters on Amazon for $20 or less. Put in your model and “SSD adapter”.
M S -
I would like to check which brand of SSD m.2 suitable for Macbook Air 2012? do have a list of it?
beside Samsung 850 evo, how about Crucial MX300 525GB M.2 Type 2280SS SSD?
myron oh - Antwoord
Bought a SSD OWC and dead again!
abdullahalnazzawi - Antwoord
how to know right ssd compatible with Air mid 2012 SN C02K86X0DRVC?
Arturo Marinho - Antwoord
Are there any post-installation steps that need to be taken? I replaced the drive in my MBA following this guide and it’s never really worked correctly since. For example, every time I reboot, it gives me a popup that my system was restarted due to an error.
mikebougie - Antwoord
Hi,
I bought a used logic board and now my SSD is not recognized by the system. I am not able to boot from internal SSD. Just from an external drive with Sierra on it. I tried to upgrade the system to High Sierra, but this did not work. Ended with EFI error.
Is there a way to update the SSD Driver on my “new” used logic board?
Thanks in advance
Martin - Antwoord
What’s the format of HD needed? I understand a special adaptor is needed for apple?
ben - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 33
Afgelopen 7 dagen: 222
Afgelopen 30 dagen: 814
Altijd: 206,870
