Ga door naar hoofdinhoud
MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement
Wat je nodig hebt
  1. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, Lower Case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, Battery Connector: stap 3, afbeelding 1 van 2 MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, Battery Connector: stap 3, afbeelding 2 van 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: stap 4, afbeelding 1 van 2 MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: stap 4, afbeelding 2 van 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement: stap 5, afbeelding 1 van 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement: stap 6, afbeelding 1 van 2 MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement: stap 6, afbeelding 2 van 2
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
Conclusie
28 andere personen hebben deze handleiding voltooid.
Jeff Suovanen
447.138 Reputatie
259 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.626 handleidingen geschreven
4Gids Commentaar
Very helpful! Tweezers were helpful to connect the reconnect the antenna connectors
James Walsh - Antwoord
Will a 2012 MBA wifi antenna work with a 2014 wifi card?
Archie - Antwoord
I'm getting a "Wifi: No hardware installed" with an X over the wifi icon in the Menu.
Even after I swapped the original Airport card with a second one. Neither one works. The original worked up until a short time ago. I hadn't used the Air for a few months, but when I started it up the Airport wasn't recognized.
Also, should mention that Bluetooth works fine.
Could it be the Airport cables?
Specs: 13" Air (2014) running Mojave 10.14.1
Simple Simon - Antwoord
I use a Netgear router with a Macbook Air 13, and the internet is very slow with it, and the connection is always disconnected and back on.
Bassem Abaza - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 76
Afgelopen 30 dagen: 410
Altijd: 21,701
