Ga door naar hoofdinhoud
Mac Pro First Generation RAM Replacement
    1. Mac Pro First Generation RAM Replacement, Case Panel: stap 1, afbeelding 1 van 1
      • Lift the lever to unlock the case.
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Pro First Generation RAM Replacement: stap 2, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      Anti-Static Wrist Strap
      $7.95
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Pro First Generation RAM Replacement, RAM: stap 3, afbeelding 1 van 1
      • Locate the two RAM trays at the bottom of the Mac Pro.
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Pro First Generation RAM Replacement: stap 4, afbeelding 1 van 2 Mac Pro First Generation RAM Replacement: stap 4, afbeelding 2 van 2
      • Pull the RAM tray out of the case by using both hands holding the edge of the ram board as shown.
      • Make sure you give enough time for the computer to cool down before you remove any internal hardware parts.
      Vraag FixBot
      Voeg opmerking toe
    3. Mac Pro First Generation RAM Replacement: stap 5, afbeelding 1 van 3 Mac Pro First Generation RAM Replacement: stap 5, afbeelding 2 van 3 Mac Pro First Generation RAM Replacement: stap 5, afbeelding 3 van 3
      • Push down on the ejectors on each side of a ram stick firmly and lift the RAM stick straight out carefully by holding each side.
      • To insert a new RAM stick, place the RAM into the slot with the correct orientation and push on the stick using both hands until the ejectors are clicked into place.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
22 andere personen hebben deze handleiding voltooid.
Andrew Kim
1.263 Reputatie
3 handleidingen geschreven
Cal Poly, Team 6-24, Maness Fall 2014 Lid van Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Leden
66 handleidingen geschreven
2Gids Commentaar
What is the name/or type of memory chip to use in the MacPro 2008.
Curtis - Antwoord Deel
Hi Curtis, hope you found the RAM type ok.
Basically server RAM, ECC, 667Mhz, FB always in Pairs.
Retired Apple, PC etc engineer.
coopernewlyn - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 75
Altijd: 22,155
