Ga door naar hoofdinhoud
MSI MS-1782 GPU Replacement
Wat je nodig hebt
  1. MSI MS-1782 GPU Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 GPU Replacement: stap 2, afbeelding 1 van 3 MSI MS-1782 GPU Replacement: stap 2, afbeelding 2 van 3 MSI MS-1782 GPU Replacement: stap 2, afbeelding 3 van 3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 GPU Replacement, Cooling Assembly: stap 3, afbeelding 1 van 3 MSI MS-1782 GPU Replacement, Cooling Assembly: stap 3, afbeelding 2 van 3 MSI MS-1782 GPU Replacement, Cooling Assembly: stap 3, afbeelding 3 van 3
    • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
    • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
  4. MSI MS-1782 GPU Replacement: stap 4, afbeelding 1 van 3 MSI MS-1782 GPU Replacement: stap 4, afbeelding 2 van 3 MSI MS-1782 GPU Replacement: stap 4, afbeelding 3 van 3
    • Gently detach the fan connector.
    • Remove the fan by lifting it out of its housing.
    • Be sure to handle the wire delicately; if not it will break.
  5. MSI MS-1782 GPU Replacement: stap 5, afbeelding 1 van 3 MSI MS-1782 GPU Replacement: stap 5, afbeelding 2 van 3 MSI MS-1782 GPU Replacement: stap 5, afbeelding 3 van 3
    • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
    • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
  6. MSI MS-1782 GPU Replacement: stap 6, afbeelding 1 van 3 MSI MS-1782 GPU Replacement: stap 6, afbeelding 2 van 3 MSI MS-1782 GPU Replacement: stap 6, afbeelding 3 van 3
  7. MSI MS-1782 GPU Replacement: stap 7, afbeelding 1 van 3 MSI MS-1782 GPU Replacement: stap 7, afbeelding 2 van 3 MSI MS-1782 GPU Replacement: stap 7, afbeelding 3 van 3
    • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
    • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
  8. MSI MS-1782 GPU Replacement: stap 8, afbeelding 1 van 3 MSI MS-1782 GPU Replacement: stap 8, afbeelding 2 van 3 MSI MS-1782 GPU Replacement: stap 8, afbeelding 3 van 3
    • Gently lift the heat sink and then pull forwards towards you.
  9. MSI MS-1782 GPU Replacement, GPU: stap 9, afbeelding 1 van 3 MSI MS-1782 GPU Replacement, GPU: stap 9, afbeelding 2 van 3 MSI MS-1782 GPU Replacement, GPU: stap 9, afbeelding 3 van 3
    • Remove the two 5.0 mm screws holding the GPU by using a JIS #1 screwdriver.
  10. MSI MS-1782 GPU Replacement: stap 10, afbeelding 1 van 3 MSI MS-1782 GPU Replacement: stap 10, afbeelding 2 van 3 MSI MS-1782 GPU Replacement: stap 10, afbeelding 3 van 3
    • Gently lift the GPU and pull to remove it from the laptop.
Conclusie
Enmanuel Mota
229 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 38
Altijd: 468
