Ga door naar hoofdinhoud
MSI GP72 6QE NVMe Replacement Replacement
Wat je nodig hebt
  1. MSI GP72 6QE NVMe Replacement Replacement, Remove the hinge cover: stap 1, afbeelding 1 van 3 MSI GP72 6QE NVMe Replacement Replacement, Remove the hinge cover: stap 1, afbeelding 2 van 3 MSI GP72 6QE NVMe Replacement Replacement, Remove the hinge cover: stap 1, afbeelding 3 van 3
    • First, power off the computer and remove all attachments, such as keyboards, mouse, external screens, network cable, USB devices.
    • Next, remove the hinge cover using the plastic opening tool. Gently lift from one side the other, then lift vertically.
  2. MSI GP72 6QE NVMe Replacement Replacement, Remove the bottom cover: stap 2, afbeelding 1 van 3 MSI GP72 6QE NVMe Replacement Replacement, Remove the bottom cover: stap 2, afbeelding 2 van 3 MSI GP72 6QE NVMe Replacement Replacement, Remove the bottom cover: stap 2, afbeelding 3 van 3
    • Next turn the computer over so the base is upward. Remove the 19 retaining screws. Four on the bottom, four on the top, two on one side, three on the other side and remaining screws in the middle as shown.
    • Gently remove the cover, starting at the back near the fan.
    • Lift the cover gently from the back, along both sides towards the front and remove.
  3. MSI GP72 6QE NVMe Replacement Replacement, Replace the nvme disk: stap 3, afbeelding 1 van 2 MSI GP72 6QE NVMe Replacement Replacement, Replace the nvme disk: stap 3, afbeelding 2 van 2
    • Remove the single retaining screw holding the current nvme disk; here the Samsung 960 EVO.
    • Replace with the new disk, such as larger capacity or newer disk.
Conclusie
Kevin
228 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 159
