Inleiding
Even though it is highly un likely that your MSI GP62MVR 6RF Leopard Pro keyboard will completely fail, even just one broken or damaged key can cause enough problems as to be worth the trouble of replacing the entire keyboard. For this task, you will need a Philips #0 screwdriver, a Jimmy tool, a prying tool, a soldering iron, and a pair of latex gloves. No special skills are required. Although the latex gloves are not required, we recommend them to avert the hazard of electrical shock or the leaving of residue on sensitive electrical components on the motherboard.
For more information on soldering and desoldering connections, please visit the How to Solder and Desolder Connections guide.
Wat je nodig hebt
Place the laptop upside down.
Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
Using a Phillips #0 Screwdriver, remove the single 5.5 mm screw fastening the battery to the body of the computer.
Remove the battery from the device.
Reorient the computer, if necessary, with a 180 degree turn so that the speakers face you.
Using a Phillips #0 screwdriver, remove twelve 4.5 mm screws fastening the heat sink to the motherboard.
Unclip the red, blue, and black intertwined wire gently from the left side of the motherboard.
Detach the black and red wire from the right side of the motherboard, as well as peel away the black tape connecting the large black wire to the motherboard.
At the middle-top right of the motherboard, there is a ribbon wire connection to the USB port.
Detach the white and blue motherboard ribbon from the USB port.
At the top right of the motherboard, there is a wired connection to the charging port.
Disconnect the grey charger wire from its clip on the motherboard.
Één andere persoon heeft deze handleiding voltooid.
