Ga door naar hoofdinhoud
Logitech Webcam Pro 9000 USB Cable Replacement
Wat je nodig hebt
  1. Logitech Webcam Pro 9000 USB Cable Replacement, Front and Back Cover: stap 1, afbeelding 1 van 2 Logitech Webcam Pro 9000 USB Cable Replacement, Front and Back Cover: stap 1, afbeelding 2 van 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 USB Cable Replacement: stap 2, afbeelding 1 van 2 Logitech Webcam Pro 9000 USB Cable Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 USB Cable Replacement, USB Connection: stap 3, afbeelding 1 van 2 Logitech Webcam Pro 9000 USB Cable Replacement, USB Connection: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers to grasp the white wire connector on the back of the motherboard.
    • Wiggle the connector back and forth to remove it from the socket.
  4. Logitech Webcam Pro 9000 USB Cable Replacement: stap 4, afbeelding 1 van 2 Logitech Webcam Pro 9000 USB Cable Replacement: stap 4, afbeelding 2 van 2
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
  5. Logitech Webcam Pro 9000 USB Cable Replacement, USB Cable: stap 5, afbeelding 1 van 3 Logitech Webcam Pro 9000 USB Cable Replacement, USB Cable: stap 5, afbeelding 2 van 3 Logitech Webcam Pro 9000 USB Cable Replacement, USB Cable: stap 5, afbeelding 3 van 3
    • Wedge the pointy end of the spudger between the sliver E-ring and USB attachment base to extract the E-ring and release the USB cable.
  6. Logitech Webcam Pro 9000 USB Cable Replacement: stap 6, afbeelding 1 van 2 Logitech Webcam Pro 9000 USB Cable Replacement: stap 6, afbeelding 2 van 2
    • Feed the end of the disconnected USB cable through the back cover.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Cory Davis
236 Reputatie
4 handleidingen geschreven
Cal Poly, Team 12-34, Amido Spring 2013 Lid van Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Leden
16 handleidingen geschreven
4Gids Commentaar
Ich habe auch. ich braucht neu Kabel für C910 aber wo finden?
wohlgemuth1981 - Antwoord Deel
where i baught pro 9000 Cable
Shiva Ji Sachan - Antwoord Deel
In hindsight, I wish I had just ordered a new camera. It is more difficult than these instructions make it look. I found a replacement cable on Amazon. Disassembly and removal of the old cable was easy. Soldering of the single wire on the new cable was difficult. I'm not as steady as I used to be, and the tiny cable and small board made it a difficult task. Once I finished the soldering, reassembly was easy except for the cable clip. Once done and I plugged it in, the camera would not work--USB device not recognized. I don't know whether the cable was incorrect or if I messed something up during the soldering. I finally trashed the old camera and ordered a new Logitech c920s. Wasted $10 on the failed cable and spent $70 on the new camera.
If you are unsure, it might be worth spending the money to upgrade instead of wasting time and money on a failed replacement cable like I did.
Ron Anderson - Antwoord Deel
As an update to the above-- My repair failed because I had ordered the wrong cable.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 40
Altijd: 7,183
