Ga door naar hoofdinhoud
Logitech UE MegaBoom Power Button Replacement
Wat je nodig hebt
    1. Logitech UE MegaBoom Power Button Replacement, Outer Mesh: stap 1, afbeelding 1 van 3 Logitech UE MegaBoom Power Button Replacement, Outer Mesh: stap 1, afbeelding 2 van 3 Logitech UE MegaBoom Power Button Replacement, Outer Mesh: stap 1, afbeelding 3 van 3
      • Locate the ends of the speaker.
      • Put a plastic opening tool in-between the rubber end and the mesh.
      • Apply a upward force in order to pry open the end.
      • Apply this procedure to the other side as well.
      • Will take force.
      • Using metal tools may permanently mar your device.
      Vraag FixBot
      Voeg opmerking toe
    2. Logitech UE MegaBoom Power Button Replacement: stap 2, afbeelding 1 van 3 Logitech UE MegaBoom Power Button Replacement: stap 2, afbeelding 2 van 3 Logitech UE MegaBoom Power Button Replacement: stap 2, afbeelding 3 van 3
      • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
      • You will hear clicks as it pries up, don't worry.
      • Remove all the rubber you pried off.
      Vraag FixBot
      Voeg opmerking toe
    3. Logitech UE MegaBoom Power Button Replacement: stap 3, afbeelding 1 van 2 Logitech UE MegaBoom Power Button Replacement: stap 3, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
      • Work the plastic retainer out of the channel all the way around the speaker.
      • Be gentle, it is easy to damage the fabric.
      • Repeat for other side.
      Vraag FixBot
      Voeg opmerking toe
    1. Logitech UE MegaBoom Power Button Replacement, Power Button: stap 4, afbeelding 1 van 2 Logitech UE MegaBoom Power Button Replacement, Power Button: stap 4, afbeelding 2 van 2
      • Locate the end of the speaker which contains the power button.
      • The circuit board which contains the power button should be visible.
      • Grasp the outer rim of this end cap and pull in an upward motion.
      • This might require some force.
      Vraag FixBot
      Voeg opmerking toe
    2. Logitech UE MegaBoom Power Button Replacement: stap 5, afbeelding 1 van 1
      • Insert a opening tool between the circuit board and one of the black clips which is holding the board in place.
      • Using the opening tool pry up on the clip allowing the board to be freed. Pry up on the second clip to fully release the board.
      • Using your fingers lift the board out of place.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Oscar Ambriz
978 Reputatie
6 handleidingen geschreven
Cal Poly, Team S9-G2, Banghart Fall 2017 Lid van Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
4 Leden
36 handleidingen geschreven
3Gids Commentaar
Will it still be waterproof after repairing?
TechBrush - Antwoord Deel
that would be a negative unless you really know what you are doing and can waterproof it
Justin Doubikin - Antwoord Deel
nice piece. i was able to follow the guide and got it right taking out the board. please where can one purchase the power button board. thanks
tony - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 68
Altijd: 5,480
