Ga door naar hoofdinhoud
Logitech UE MegaBoom 3 Battery Replacement
Wat je nodig hebt
  1. Logitech UE MegaBoom 3 Battery Replacement, General Disassembly: stap 1, afbeelding 1 van 2 Logitech UE MegaBoom 3 Battery Replacement, General Disassembly: stap 1, afbeelding 2 van 2
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech UE MegaBoom 3 Battery Replacement: stap 2, afbeelding 1 van 3 Logitech UE MegaBoom 3 Battery Replacement: stap 2, afbeelding 2 van 3 Logitech UE MegaBoom 3 Battery Replacement: stap 2, afbeelding 3 van 3
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
    Vraag FixBot
    Voeg opmerking toe
  3. Logitech UE MegaBoom 3 Battery Replacement, Battery: stap 3, afbeelding 1 van 3 Logitech UE MegaBoom 3 Battery Replacement, Battery: stap 3, afbeelding 2 van 3 Logitech UE MegaBoom 3 Battery Replacement, Battery: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Remove the lithium-ion battery from the inside of the speaker by gripping the battery using the plyers.
    • Here, it is ideal to use a tweezers as opposed to the plyers, however, the plyers makes it so much easier to take out the battery.
    • The battery should slide out as you pull against it with the plyers.
    • Remove the battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Jason Doland
124 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 101
Afgelopen 30 dagen: 250
Altijd: 4,164
