Inleiding
Use this guide to replace the motherboard in a Logitech UE Hyperboom Bluetooth Speaker. The motherboard sends and receives signals to and from every component in the speaker. Signs of motherboard issues are total power failure, inability to charge, connections issues, or a physical burning smell. If any or multiple of these apply, it is possible you have a motherboard issue.
Note: Although the speaker replacement guide is listed as a prerequisite, you only need to remove the speakers at the near the top panel to access the motherboard (i.e. skip steps 5 & 6).
Before beginning this guide, be sure to power off your speaker.
Wat je nodig hebt
Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
Use the Jimmy to pry the fiber mesh cover away from the speaker.
Take the fiber mesh off of the speaker completely.
