Inleiding
The Logitech UE Boombox has two tweeter speakers that may need replacement due to use over time. They are essential for receiving high quality sound.
Wat je nodig hebt
Use a metal spudger to pry open the power button cover.
Once the power button cover is slightly opened, use your fingers to remove the power button cover.
Remove the fifteen 13.0 mm Phillips #2 screws from the side of the device containing two speakers.
Separate the two halves by gently pulling them apart.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
Could you recommend anywhere to find the correct replacement tweeters & drivers?
