Ga door naar hoofdinhoud
Logitech UE Boom 3 Battery Replacement
Wat je nodig hebt
  1. Logitech UE Boom 3 Battery Replacement, Base: stap 1, afbeelding 1 van 2 Logitech UE Boom 3 Battery Replacement, Base: stap 1, afbeelding 2 van 2
    • Flip the speaker so the base is facing upwards.
    • Place the iFixit opening picks in the gaps of the speaker.
    • Use the picks to pry open the speaker.
    Vraag FixBot
    Voeg opmerking toe
  2. Logitech UE Boom 3 Battery Replacement: stap 2, afbeelding 1 van 2 Logitech UE Boom 3 Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a Jimmy to completely pry the base away from the rest of the speaker.
    Vraag FixBot
    Voeg opmerking toe
  3. Logitech UE Boom 3 Battery Replacement, Battery: stap 3, afbeelding 1 van 3 Logitech UE Boom 3 Battery Replacement, Battery: stap 3, afbeelding 2 van 3 Logitech UE Boom 3 Battery Replacement, Battery: stap 3, afbeelding 3 van 3
    • Remove the adhesive strap holding the battery in place.
    • It is sticky and tightly bounded, but removal is necessary.
    • Pull out the battery by hand until it is out of the casing and being held by the cable only.
    Vraag FixBot
    Voeg opmerking toe
  4. Logitech UE Boom 3 Battery Replacement: stap 4, afbeelding 1 van 2 Logitech UE Boom 3 Battery Replacement: stap 4, afbeelding 2 van 2
    • The battery will still be attached to motherboard via cable.
    • Carefully press down on the lever on the end of the cable and disconnect it from the motherboard.
    • This cable is intricate and is susceptible to damage beyond repair. Be extra careful to precisely insert and remove the cable as bending the pins can result in damage.
    • Remove the battery from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ethan Donahue
603 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 1-4, Konn Spring 2024 Lid van UMass Dartmouth, Team 1-4, Konn Spring 2024
UMASSD-KONN-S24S1G4
4 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 262
Altijd: 5,408
