Ga door naar hoofdinhoud
Deze vertaling geeft mogelijk niet de meest recente updates van de bronhandleiding weer. Help ons met het updaten van de vertaling of bekijk de bronhandleiding.
Logitech Performance MX Left Click Repair
Wat je nodig hebt
    1. Logitech Performance MX Left Click Repair, Turn off the mouse and remove the battery: stap 1, afbeelding 1 van 1
      • On the back of the mouse, slide the power switch so that the red area is showing to turn off the mouse. Pry open the panel on the bottom to remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    2. Logitech Performance MX Left Click Repair, Remove the 3 pads: stap 2, afbeelding 1 van 1
      • To access the screws necessary to open the mouse, you must remove the pads on the bottom of the mouse. Use a sharp tool such as an iFixit Jimmy tool or an X-acto knife to separate the pad from the case. Each pad has two layers. Ideally, both should remain attached, but this is hard to achieve.
      Vraag FixBot
      Voeg opmerking toe
    3. Logitech Performance MX Left Click Repair, Remove the 4 screws: stap 3, afbeelding 1 van 1
      • Use a 00 Phillips-Head screwdriver to remove the screws at the bottom of the mouse.
      Vraag FixBot
      Voeg opmerking toe
    4. Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: stap 4, afbeelding 1 van 3 Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: stap 4, afbeelding 2 van 3 Logitech Performance MX Left Click Repair, Remove the upper part of the mouse: stap 4, afbeelding 3 van 3
      • Slide the bottom laterally while lifting.
      Vraag FixBot
      Voeg opmerking toe
    5. Logitech Performance MX Left Click Repair, (optional) remove the connector: stap 5, afbeelding 1 van 1
      • This step isn't necessary, but it makes it easier to work on the mouse.
      Vraag FixBot
      Voeg opmerking toe
    6. Logitech Performance MX Left Click Repair, (optional) put a bit of tape on top of the microswitch: stap 6, afbeelding 1 van 1
      • This helps to avoid losing the white piece.
      Vraag FixBot
      Voeg opmerking toe
    7. Logitech Performance MX Left Click Repair, Remove the multiswitch top: stap 7, afbeelding 1 van 2 Logitech Performance MX Left Click Repair, Remove the multiswitch top: stap 7, afbeelding 2 van 2
      • Use your spudger to push the vertical front part of the multiswitch outwards to unhook the top part of the switch casing.
      Vraag FixBot
      Voeg opmerking toe
    8. Logitech Performance MX Left Click Repair, Flatten the metallic piece: stap 8, afbeelding 1 van 2 Logitech Performance MX Left Click Repair, Flatten the metallic piece: stap 8, afbeelding 2 van 2
      • Flatten the metallic piece of the multiswitch (it will probably be curved upward) until you get a neat "click" sound.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble the mouse, follow the instructions in the reverse order.
12 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
94%
Deze vertalers helpen ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
Samuel Colin
717 Reputatie
2 handleidingen geschreven
8Gids Commentaar
merci , ca vient de sauver ma Revolution
Clement Renaut - Antwoord Deel
Avec plaisir. J'en suis ravi :)
Samuel Colin - Antwoord Deel
Thank you, this worked flawlessly. Your time and effort is well appreciated.
Kenji Lum - Antwoord Deel
Thank you so much. My left click often unregisters incorrectly. If not for step 7 and 8, I wouldn't have opened the multiswitch top and clean the contact point. Seems to work perfectly normal now. It'd be a waste to throw away the whole item just because of a tiny defective component. Thanks again for helping me fixed it.
Thuan Chau - Antwoord Deel
@Kenji @thuan: I'm glad I could help. Thanks for your comments!
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 193
Altijd: 25,725
