Ga door naar hoofdinhoud
Logitech Mouse G302 Disassembly
Wat je nodig hebt
    1. Logitech Mouse G302 Disassembly, Open the case: stap 1, afbeelding 1 van 2 Logitech Mouse G302 Disassembly, Open the case: stap 1, afbeelding 2 van 2
      • Turn the mouse over to access the bottom.
      • Using a scalpel, pick, or similar tool, peel off the front and rear soles (slide pads) on the bottom of the mouse. This exposes three screws.
      • Using a Phillips #0 driver, remove the three screws circled in red.
      • Use care to salvage as much of the sole adhesive as possible, in order to reuse it. If, however the adhesive is inadequate on reassemby, contact cement is a good substitute.
      • Carefully separate the two halves of the case. Light prying may be required. If you examine the second photo you can see one of the plastic retaining tabs on the front of the top half. A pick or similar tool prove helpful without marring the case.
      • Remove the three Phillips PH000 screws circled in orange; The PCB can then be removed for inspection and repair.
      Vraag FixBot
      Voeg opmerking toe
    2. Logitech Mouse G302 Disassembly, Switch replacement: stap 2, afbeelding 1 van 2 Logitech Mouse G302 Disassembly, Switch replacement: stap 2, afbeelding 2 van 2
      • The switch manufacturer is Omron, part number: D2FC-F-7N. The switches have three lead pins, two of which are used.
      • My experience was one switch working intermittently. In such a case, I recommend replacing both the left and right switches.
      Vraag FixBot
      Voeg opmerking toe
    3. Logitech Mouse G302 Disassembly, Switch information: stap 3, afbeelding 1 van 1
      • This may be helpful in finding the correct or compatible replacement i.e. online vendors such as AliExpress.
      • What I used as a successful replacement: RS Components Stock No. 682-1519 microswitch. Manufactured by Omron—part number: D2F-F.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Carsten Dahl Hjarup
3.128 Reputatie
9 handleidingen geschreven
2Gids Commentaar
what is the name and type of switch number 3 / sw3
Yanuar Arifiyanto - Antwoord Deel
Did the job on my own mouse just tonight. The screws are actually Phillips #000, not #0 as indicated in the guide.
Michael G - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 32
Afgelopen 30 dagen: 96
Altijd: 7,573
